Newbie here with a noob question?
Old Aug 3, 2012 | 12:34 AM
La24's Avatar
La24
Default Newbie here with a noob question?
My low tire pressure light is on and I can't seem to fix it. I did what the owners manual said, set front tires to spec 35 psi, rears to 38 psi, and spare to 60 psi. Then I tried initializing it but nothing happens, lights are still on. Could it be one of the sensors are bad? How can you check if one of the sensors are bad? I believe these are the stock wheels and tires.
Old Aug 3, 2012 | 12:39 AM
krUnALv99's Avatar
krUnALv99
Try unhooking the battery and hooking it back up so everything will reset....
just dont 2 cents...
dont flame me.
Old Aug 3, 2012 | 12:45 AM
La24's Avatar
La24
How long should I unhook the battery? Thanks for the reply
Old Aug 3, 2012 | 02:20 AM
krUnALv99's Avatar
krUnALv99
i would think unhooking it n hooking it back up should be fine.
but you can leave it unhooked for 30 seconds and hook it back up
Old Aug 3, 2012 | 06:36 AM
SC400MAN's Avatar
SC400MAN
It also takes driving the car for several miles for the TPMS to reset.
Old Aug 3, 2012 | 07:43 AM
3sgte_slow's Avatar
3sgte_slow
When you look on the gauge cluster, does it say "tire pressure low" or does it say "check system"?
If it says "check system", I think that because of a bad sensor.
If it says "tire pressure low" it just needs air, disconnect the battery and try again.
Kpalmer196
17
Aug 7, 2018 07:27 PM
yama
Jan 7, 2018 08:59 PM
tomiv9
Aug 30, 2015 05:58 PM
See5
Aug 26, 2013 04:19 PM
sf7307
Mar 24, 2008 09:48 AM
