ES300 High Pitch whistling sound
Old 07-25-12, 07:26 AM
Braver
Braver's Avatar
Default ES300 High Pitch whistling sound
I have a 2001 ES300 that makes a high pitch whistling sound from the fan belt area first thing in the morning that lasts about 20 seconds and goes away when I backup.The sound is heard only when the air conditioner is on. The mileage is 104K miles.Does anyone know what the is the cause for this problem? Thanks.
Old 07-25-12, 08:26 AM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
It sounds like the belt is ready for replacement. It may be glazed over causing the sound you are hearing. I suggest replacing both belts, the power steering belt, and the alternator/air conditioning belt.
The belts are cheap you should be able to get both for $20. Labor will be around 1/2 hour to 1 hour.
Old 07-25-12, 09:13 AM
INNOUTFAN
INNOUTFAN's Avatar
When you go to change the belts, do one at a time, and start the car in between. Could also be a bearing - alternator, A/C Compressor, idler pulley, power steering pump all have bearings that can sing on start-up then stop at operating temperature.
Old 07-25-12, 01:54 PM
Braver
Braver's Avatar
Thank you for your response. I checked the car again without having the air conditioner on and there is no high pitch whistling sound. After warm up, I turned the a/c and the sound is not there. So it appears that the problem occurs only when the engine is cold at the first start in the morning when the a/c is also on.
Old 08-07-12, 05:33 PM
Aqualung
Aqualung's Avatar
I have the same sound, same year...had the belt lubed...but...my tech says that the bearings are also going and I'll need a new compressor.
Old 08-18-12, 04:30 AM
Braver
Braver's Avatar
Default ES300 High Pich whistling sound
Did the belt lube stop the whistling sound? The problem also occurs in the winter when the engine is cold during startup.
Old 08-20-12, 10:17 PM
Kenny43
Kenny43's Avatar
Your best bet is to just replace the belts at the same time
RookieLEX
ES - 5th Gen (2007-2012)
06-05-17 11:37 AM
tomstep2
07-16-09 08:13 PM
Pescao
RX - 1st Gen (1999-2003)
03-02-09 07:30 PM
underpsi
Performance & Maintenance
05-06-07 12:21 PM
LAMF
10-16-06 05:28 PM
Quick Reply: ES300 High Pitch whistling sound
