LS 460 - DIY Oil Change
Old 06-18-12, 05:18 PM
drydens
drydens's Avatar
Default LS 460 - DIY Oil Change
Help. I want to change my own oil. I cannot find any procedures for how to do this (in fact, i cannot seem to even find the Oil Filter). Help please!
Old 06-18-12, 05:24 PM
caddyowner
Recovering Lexus Addict
caddyowner's Avatar
The LS460 forum has a number of threads on this. Do a search on oil change in the title of threads in that forum
Example:
https://www.clublexus.com/forums/ls4...re-w-pics.html
Old 06-18-12, 07:08 PM
Lextrician
Lextrician's Avatar
I will give you hint as to where to locate the oil filter, under the car there is a little trap door with one 10mm bolt holding it.
Old 06-19-12, 03:30 AM
peteharvey
peteharvey's Avatar
Get some ramps esp. Raceramps @ raceramps.com made of solid synthetic rubber [used in the space shuttle].
Open the trap door.
Remove the top oil cap.
Drain the old oil into a a pan.
Buy a SST Special Service Tool from Lexus, to remove the oil filter cannister.
Attach a 3/8" square socket drive to the SST, to remove the oil filter cannister.
Remember to clean the oil filter cannister thoroughly with detergent, rinse thoroughly, and dry thoroughly.
Buy a new oil filter from Lexus, and insert it into the cannister.
The new oil filter from Lexus also contains a couple of brand new rubber o-rings.
Smear oil around the rubber o-rings.
Tighten.
Refill the oil.
Best to use fully synthetic 5W30...
Old 06-19-12, 04:32 AM
GregCon
GregCon's Avatar
Why would you best use 5W-30 when it is not even recommended by Lexus?
Old 06-19-12, 11:10 AM
Lextrician
Lextrician's Avatar
0-20 or 5-20. the 0-20 for fuel economy walmarts normally have 5 quart jugs for cheap
Old 06-19-12, 12:05 PM
GregCon
GregCon's Avatar
I'm not trying to bust your chops, but using those ramps puts the car in a non-level position which won't be conducive to getting a proper drain.
Old 06-19-12, 12:11 PM
Lextrician
Lextrician's Avatar
the oil filters i get come with a drain plug, so you can use that
Old 06-19-12, 01:23 PM
FLDJM
FLDJM's Avatar
Did your car come witht the aluminum oil filter housing or did you change it with the toyota tundra part?
Old 06-19-12, 01:54 PM
Nospinzone
Nospinzone's Avatar
I was thinking the same thing. I've never changed the oil on my LS so I don't know how that position affects a complete drain. However, you know a dealer has the vehicle level so it would seem that Lexus would design the drain to accomodate that position.
On the other hand, a small amount of old oil isn't going to make a significant difference since you're putting in 9.0 quarts instead of 9.1.
Old 06-19-12, 03:22 PM
GregCon
GregCon's Avatar
Yeah, it depends on the oil pan design how much will be left in the pan.
About 12 years ago I decided no more lying under cars for me so I bought a Mohawk 9,000lb lift. Which brings me to my next point - the LS is not well-equipped to be lifted as the factory lift points are small and flimsy.
Old 06-23-12, 11:24 AM
bud hurley
bud hurley's Avatar
i bought a set of raceramps and they work great. $203 on amazon and free shipping for the 56" long ones.. had them in two days. the oil actually drains better with the car on the ramps because the drain plug is in the rear of the pan. as well as the ls460 the ramps work well for the toyota sequoia suv, the smart car, the john deere tractor, the john deere zero turn mower and anything else that i want to get under. very useful tool.........bud
Old 06-23-12, 11:45 AM
I8ABMR
I8ABMR's Avatar
always pretty simple to just take it to a shop. Its pretty damn cheap and a lot less time. I applaud you DIY guys. I just dont have the time, patience, or skill. I wish I did....
Old 06-23-12, 11:01 PM
chris07ls
chris07ls's Avatar
The drain plug is on the back of the oil pan, so a slight incline actually helps. I have now done about 12 oil changes on my 07 and find it a lot faster than going to the dealer, plus I know everything was done to spec.
Old 06-24-12, 05:14 AM
Silverpaws
Silverpaws's Avatar
Quick Reply: LS 460 - DIY Oil Change
