UCA squeak but UCA/LBJ are new
Old 03-06-12, 09:45 AM
Zoolander
Zoolander's Avatar
Default UCA squeak but UCA/LBJ are new
I had this problem last year so I replaced the UCA and LBJ to fix the issue. I just recently replaced the UCA again cause the issue came back. Before I replace the LBJ again, could it be anything else? Upper strut mount? It is definitely a metal on metal sound that occurs whenever the wheel is turned or the car goes over a bump in the road.
Old 03-06-12, 10:15 AM
GS4_Fiend
GS4_Fiend's Avatar
Open the hood and check the upper strut bushing see if its cracked
Old 03-06-12, 01:20 PM
Zoolander
Zoolander's Avatar
Doesn't appear to be.
Attached Thumbnails UCA squeak but UCA/LBJ are new-img-20120306-00842.jpg
Old 03-06-12, 02:32 PM
gsxrfeen
gsxrfeen's Avatar
I recently went to a Lexus dealer complaining about squeaking and croaking whenever i drove on uneven road, they told me it was the UCA and front upper shock/strut insulator/mount/support. Total estimate was $2780 so I got the itemized list of the part numbers and will get the parts on my own and hopefully find a independent shop. Did you use OEM parts or aftermarket parts when you replaced them last year? If you need part numbers let me know. good luck
Old 03-06-12, 05:14 PM
GS714
GS714's Avatar
Default Well well well, I think I found some help here LOL
This is what posted in the suspension and brake section but no respond, I am suspecting at the same general area.
Folks, Please help
This is how my problem have developed. I replaced all four struts with KYB GR2 about four months ago. All struts mouth are still OEM. Three weeks later, I replaced the LBJs with OEM joints (Wanna a hit anyone?) No problem at all everything was quiet. About two weeks ago, when I reversed and put the gear shifter into "D" I heard a big bang/crack/popping noise when I stepped on the gas. From that day on. Every time I turn the steering wheel, the passenger front corner generated a rubber squeaking sound at first, and now has evolved into the clunking noise when turning the steering wheel while parking the car. the sound (clunking) also arose only when making a turn to the left at slow speed. And every time I step on the gas at the stop light or from completed stop. When I rock the car with the hood up, the clucking/clicking sound is very prominently heard from the strut mount and strut bolt.
Should I start out replacing?
1. Strut mount
2. Strut OEM ( I am think of going back to OEM)
3. Caster Arm (or Separate Bushing and Press it in)
4. Outer/Inner Rods.
5. Steering/Rack Bushing
What other option should I look for. I already took the car to three shop.
I'm starting to like the car and its running yellow light power. But the F..Cking clunking really bug me and a real major turn off.
GRAND_LS 4
05-19-20 01:23 AM
TakaM
Suspension and Brakes
03-04-19 11:40 AM
funcrusher
06-08-16 10:27 PM
jwigley
RX - 1st Gen (1999-2003)
12-29-14 07:52 PM
MrApex
06-02-04 10:52 PM
Quick Reply: UCA squeak but UCA/LBJ are new
