Speed Sensor Wire location
HI, People!
I'm trying to install avic D2 to my RX330 (2004), and i need to connect HU to speed sensor wire (VSS). Where is that wire?
Thanks!
Thanks!
no pics avail on directechs..but you can also try ECM, second plug from top, pin 17 lt green wire (behind glove box) or
The VSS wire is also lt. blue at the amplifier under the passenger side rear seat.
Thank You for your response! I cant find this ECU module. I opened the glovebox and only thing i see is Cabin air filter compartment!
PS. What this VSS doing on amp? are you sure about that blue wire on non navigation amp?
disconnect the neg batt terminal... then with the ecm mounted in the vehicle(or held up like its mounted) unplug the 2nd harness from the top.. look at the wire side of the plug... should have #'s at each corner.. locate the # closest to 17 an count over til u locate a light green wire it should be in pin 17 if u counted properly..
Waking this thread from the dead. Looking for the speed wire on a 2009 RX350. Looking at the ECU harness the 2nd from the top, I see no light green wire, just a normal color green wire. I've search every way I know how on here and across the internet to no avail. Any help greatly appreciated!
DjFergi
03-16-05 06:46 PM
