Common leak points on an sc400?
Hello i just purchased A 97 sc400, took it in to replace sparkplugs, but the technician called me and said before i do this i would like to warn you the spark plugs wires might get stripped so i said hold off on that he also told me:
I have oil leaks and he couldn't tell me where.
What would be some spots to look at or replace?
Thank you~!
Thank you~!
first off can we get some more info about your car, mileage, general condition of the engine bay (this is where pics would help) do you have any maintenace records from the previous owner. do you have a general understanding of cars to get in there and look at the car and decipher what u see?
and what sort of mechanic are you taking your car too that he cant figure out where a leak is coming from. doesnt he have dye and a UV light???
Uh, if a mech told me wires might get stripped just by replacing plugs I'd be like "wut". Okay, maybe your wires are dinosaurs, but still...
anyways you should do plugs yourself, very easy, and yes dye and UV light fo sezzle ma bezzle
ya thats ridiculous if the mechanic cant find where a leak is coming from. common leaking points on these cars depends on how many miles and what year it is. I had a 97 and I replaced the valve cover gaskets, cam and crank seals, dipstick tube o-ring, rear main seal, and the shift shaft seals on the side of the trans. all of these are fairly common when approaching 200k miles.
I've got a solid six spots under my car that leak right now lol. Pretty sure the tranny drain plug is leaking a little, possibly the pan, definitely the tatters of both boots on the steering rack, I think the PS pump, and valve covers. Mileage and lack of maintenance will do it every time.
Thanks for the replies. I know for a fact my valve covers are leaking, possibly my oil pan, and possibly my cam seals but i am having the cam seals replaced once i do my timing belt and water pump in a few weeks.
I want to be able to replace the valve cover gaskets myself also the pan. Is this hard for a beginner. When i mean beginner, i mean i never done anything mechincal to my cars. Don't even have tools but will buy some soon.
As for the mechanic yeah i think he just wanted more money out of me cause he said he would have to degrease the engine which would cost me $60 then he could tell....
