Speedo & RPM not working sc400
Old 09-11-11, 05:59 PM
lcrusader
lcrusader's Avatar
Default Speedo & RPM not working sc400
So a few days ago the speedo and RPM meter stopped working. Everything else works fine and the dash still lights up, but the two just doesn't move.
Someone had told me it was the ignitor
looks like this
but im kinda doubting it... Ive searched around and there hasn't been a lot of answer to this. Anyone have any clue?
Old 09-11-11, 06:32 PM
Arkansas
Arkansas's Avatar
Try slapping the dash above the cluster. My 92 sc400 does the same thing and slapping the dash does the trick.
Old 09-11-11, 07:22 PM
FatBrian81
FatBrian81's Avatar
The speedo and tach needles have capacitors on the back of the cluster that help to power them. Pull your cluster and if the needles are good have all of the capacitors on each needle replaced at a local electronics repair shop. You could also DIY it if you are handy with a soldering iron.
Old 09-12-11, 12:39 AM
lcrusader
lcrusader's Avatar
well the rest of the capacitors look fine but im going to take it to work and look at it under the scope
Old 09-12-11, 01:30 AM
suislide
suislide's Avatar
i do that daily
Old 09-12-11, 11:31 AM
lcrusader
lcrusader's Avatar
slapping the dash didn't work for me btw, before I take out the capacitors I'm gonna try a new ignitor to see if that works.
Old 09-12-11, 02:08 PM
jdms13
jdms13's Avatar
nothing a quick slap couldnt fix! my speedo and tach stick on occasion... slap and fixed! lol
Old 09-14-11, 06:15 PM
lcrusader
lcrusader's Avatar
so it wasn't the capacitors, they were replaced anyways though with more efficient ones. Module should be in by Friday, ill keep updated
Old 09-15-11, 11:19 PM
BAMASOARER
BAMASOARER's Avatar
Slappa da dash!
Old 09-16-11, 08:44 PM
lcrusader
lcrusader's Avatar
bump need some help, all the caps are good circuit is good.
Old 09-17-11, 03:16 AM
WsKSilent
WsKSilent's Avatar
x2
I have the same problem and I even switched the cluster to a better condition one. It worked for like 1 week or so and ended up with the same problem.
Old 09-17-11, 08:38 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
I don't know why people still quote the lighting fix for a digital australian soarer backlight (or occasionally some LS cathode needles), it's been 8 years since anyone posted it. (PS no they don't).
No such thing.
Speedo is controlled by the main chip, that's why there is no fix posted.
Old 09-17-11, 09:27 AM
FatBrian81
FatBrian81's Avatar
No such thing.
I had posted about this problem a while back and that was the fix that was given to me, I haven't got a chance to tear everything down yet to do something about it.
Old 09-17-11, 09:28 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
You'd be sadly dissapointed if you did.
Old 09-18-11, 10:32 PM
lcrusader
lcrusader's Avatar
speedo has been fixed, RPM still isn't working.
some how both VSS #1 and #2 are both bad. I really don't know how both went bad at the same time, but I'm glad I got the speedo fixed. Now to figure out why the RPM isn't working.
Quick Reply: Speedo & RPM not working sc400
