I just went with the H&R 20mm spacer kit. You will need to run extended studs with that kit, unless you want to go the KICS route, where it has bolt-on spacers. But they are not hub-centric like the H&R.
You were on stock tt wheels with this set up? Although I have never used a spacer before hubcentric is a must so where would I look for this kit? Is this just rear or both front and rear?
20mm on the rears, but thats for my wheels. You need to look at the way your car sits with the wheels you have. get directly behind it and look, also look how far inset the very top of the wheel is from the fender and either measure or make an educated guess.
