1992 - SC400 - Fuel Pump Location
Sorry guys, but my eye ***** hurt from reading all the posts, but I can not find one post telling exactly where the fuel pump is at.
YOUR HELP WILL BE GREATLY APPRECIATED.
Thanks,
Thanks,
Ayotriple (03-24-20)
I take it you missed my post....
Step one: Remove seats. Lower section simply pops out. Back section has 3-12mm bolts (IIRC they are 12..), remove bolts, push seat in an upward direction to unseat tabs, pull forward and out.
Step Two: Look for the fuel pump cover that covers the cover...., not sure how to explain that right, but you will see it.
Step Three: remove fuel pump and do what is needed and enjoy the fumes on a hot day while sweating in the back of your SC
Ok i guess i am wrong ... Just saying i had clear view and access to it when i removed the front trunk trim when replacing my trunk struts last month but i guess u have to also remove the center seat section to remove...thanks sorry to mislead.
What you see from the trunk is the fuel gauge system, I thought the same until I removed it and saw the fuel pump all the way across the other side of the tank. The job itself was easy to do..Thanks for the information.
Jomidan
Jomidan
coach1255
09-09-17 06:30 PM
