humming noise that increases w/ speed
I believe the noise comes from the front of my car. 2006 IS250
I would compare it to a flat tire sound but a bit more quiet. The speed of the noise increases with the speed of the car. There is no vibration associated with the noise.
Any ideas?
**Update**
I've checked all lugs are torqued correctly.
I've removed my foot from accelerator and still hear the noise even when coasting.
If I remove my hands from steering wheel the car only veers to the right side of lane by a degree so I know my alignment is good.
If I brake hard I have no vibration or any more noise.
I only hear it when the radio is off or below volume level 3. (No I don't want to drive with the radio on all the time)
I'm beginning to think the front tires need replacing or perhaps a balance
Any ideas?
**Update**
How long have this sound been there? Any new parts/replacement recently?
Also, i know there's no vibration when you accelerate, but if you apply brakes firmly from about 45mph or so, does it vibrate? if so, pedal? steering wheel? or both? And at that same time, does it pull to right or left?
If it's vibrating when you brake in pedal and steering wheel, most likely warped front rotors. If it's vibrating slightly just on the pedal, then it may be rear rotors, but i'm doubting that if you are hearing sound from the front. If it pulls, they obviously need alignment and possibly tires depending on how old they are, if it's wearing unevenly.
I hate these small noises that's hard to figure out. I'm dealing with one myself.
-D
-D
I have a similar sound to yours. It first appeared around christmas and 4 - 5 days later after changing tires I thought it would dissapear but it was still there. Since then, I have changed front brake pads (the rear still have a lot material left). I also changed both front wheels bearing hubs but the sound is still there.
Next on my list is replacing the rear diff. oil and new front rotors... I'm going to change them this coming weekend so will let you know if the sound has gone away.
Rgds
George
Rgds
George
-D
-D
Rgds
George
Rgds
George
ok....i think next move is this. if you think it's front tires, i would swap out the rear with front and see if sound is still there. (assuming hte tires on back are good of course).
hopefully you can figure it out, mine is driving me nuts.
-D
-D
the usual suspects, based upon my experience over the years
1. Tires. Which tires are you running?
2. Wheel bearing. If you ever hit a pavement hard or a pothole, the wheel bearing can make this sort of noise.
Yeap, that's the next thing to do is replace tires.
While driving, veer left to right (safely) in your lane. If the pitch changes, a wheel bearing is the culprit. A bearing can make noise even if there is no free-play in the wheel.
