Ipod connection on factory stereo 1999ES300
Old 01-11-11, 11:32 AM
Nberke
Nberke's Avatar
Default Ipod connection on factory stereo 1999ES300
Is there a way to connect your IPOD to your factory stereo? Any ideas would be appreciated.
Thanks ,
Neal
Old 01-11-11, 03:10 PM
TheCarGuy2
TheCarGuy2's Avatar
FM modulator (not transmitter).
Old 01-11-11, 07:50 PM
xsh0tya
xsh0tya's Avatar
Yea the WIRED fm modulator and not wireless FM transmitter. Better quality. Sucks because some vechicles can add an ipod adapter to take over another function like SAT radio or CD changer. I havent found anything for 99 ES300. Or if you really want to get best quality and most control from your Ipod or Iphone you can change the stock radio, but this is the most expensive option.
Old 01-11-11, 08:00 PM
Nberke
Nberke's Avatar
Can you explain a wired fm mod a little better? In detail? I have now a griffin fm transmitter so i am a little confused. I have looked into aftermarket radios with ipod hook ups like pioneer that i can also add a backup camera but would really like to keep costs down.
Also, Is there a way to take the wires that go to the cd changer and adapt them for IPOD use? Meaning not use the CD changer but use your IPOD instead. I cant really explain it better but i hope you all know what im getting at here. Do they make a wire harness for this type of application?
Thanks
Neal
Old 01-12-11, 12:06 PM
01ES300NYC
01ES300NYC's Avatar
Easiest way would be......
http://www.bestbuy.com/site/Monster+...ci_sku=1469032
Old 01-12-11, 03:45 PM
QuachmanES
QuachmanES's Avatar
Right now I just use CD's, but I've been looking for an alternative. I've seen a couple DIY's around here for the ES where someone wired it up behind the dash to the CD or tape output, I don't remember which. Just do a search for it and something should come up.
Those cassette tape adapters work, but the sound is often quiet and low quality.
Old 01-14-11, 09:20 AM
xsh0tya
xsh0tya's Avatar
Thanks
Neal
Also that cassette adapter mentioned above is the easiest way but also the messiest you would just need to keep your Ipod charged or get a car charger for it. This gives you those messy looking cables on your dash but def managable and a great solution.
A FM Mod is a wired adapter. It plugs directly into your stock stereos antenna spot and then your factory antenna cable plugs into it. So when the unit is ON, your radio sees it as the strongest (well one of them) stations. So you dont have to switch stations as much (if ever) when you drive through other cities.
This is just one I found quick but gets the idea across.
http://www.amazon.com/Scosche-FM-MOD.../dp/B001QBG614
you can see that it has a port or female end for the factory antenna and a male end. The adapters I am recommending have a cable which charges your Ipod.
Old 01-15-11, 03:52 PM
jimmyjay
jimmyjay's Avatar
This thread is your answer. Still on the first page of the Lexus audio forum page.
https://www.clublexus.com/forums/lex...em-stereo.html
rollinout
03-23-15 03:25 PM
d00t
09-29-10 02:09 AM
hiendo85
05-22-08 02:23 PM
Quick Reply: Ipod connection on factory stereo 1999ES300
