GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Transfer case leak
Old 12-01-08, 03:49 PM
EJMEYERCO
EJMEYERCO's Avatar
Default Transfer case leak
I own a 2003 lexus gx470 with 55k miles on it. I recently took it in for an oil change and a couple of days after the oil change i noticed what seems to be oil dripping from around the transfer case. There seems to be a black box attached to the transfer case and i think that is where the oil is coming from. Any suggestions on what it might be or how it can be fixed?
Old 12-01-08, 03:54 PM
LXLUTHR
LXLUTHR's Avatar
there is a TSIB for this, check with your local Lexus dealership
Old 12-01-08, 04:04 PM
EJMEYERCO
EJMEYERCO's Avatar
Originally Posted by cpa lg
there is a tsib for this, check with your local lexus dealership
what is tsib?
Old 12-01-08, 04:25 PM
LXLUTHR
LXLUTHR's Avatar
Transfer Case leak, I believe it is a re-seal if not a replacement of the transfer case.
Old 12-02-08, 09:50 AM
cmarshack
cmarshack's Avatar
Originally Posted by EJMEYERCO
what is tsib?
TSB or TSIB= Toyota Service Bulletin. It occurs when Toyota recognizes a problem with a vehichle and covers it under warrantee
Old 12-02-08, 02:58 PM
cssnms
cssnms's Avatar
What years does the TSB cover?
Old 12-03-08, 11:07 AM
cmarshack
cmarshack's Avatar
Every year...as long as you are still under warrantee
Old 12-03-08, 11:47 AM
cssnms
cssnms's Avatar
Is this an issue Lexus is addressing regardless of whether it is leaking or not or does it have to leak to qualify?
Old 12-03-08, 01:14 PM
EJMEYERCO
EJMEYERCO's Avatar
Does anyone know if the TSIB actually exists for this problem?
Old 12-03-08, 08:22 PM
cmarshack
cmarshack's Avatar
I know it exists for the 03 04 models, they may have fixed the issue after that.
[QUOTE=cssnms;4054130]Is this an issue Lexus is addressing regardless of whether it is leaking or not or does it have to leak to qualify?
I would tell my tech it's leaking and he would fix it. They fixed mine without me ever asking and I have never had any leaks in my driveway.
Old 12-05-08, 05:00 AM
Capirato
Capirato's Avatar
I have a '04 and had an oil leak. Transfer case was replaced under waranty.
~ Cap
Old 12-12-08, 10:04 AM
EJMEYERCO
EJMEYERCO's Avatar
Did powertrain warranty cover it?
Old 12-12-08, 02:57 PM
DallasGX
DallasGX's Avatar
yes it will
Old 12-22-08, 02:39 PM
Faymester
Faymester's Avatar
I know it's semi-dead thread to bump, but does anyone have the TSIB code for this?
I'm possibly picking up a used GX later today or tomorrow & I want to make sure it's had all the recals taken care of.
Old 12-22-08, 08:33 PM
boxed
boxed's Avatar
What are the pre symptoms of a bad transfer case? and what years does the recall effect?
RXstate (06-05-18)
Quick Reply: Transfer case leak
