dashboard warning light
Hi,
quick question, i got the warning light on my es300 '93, the one that has the yellow colored oil can with a squiggly line under it. it comes on and off randomly.
what does it exactly mean?
awaiting for your swift responses
the thing is, ive done everything..changed all the oils etc, so wht i need is some one with a user manual for a lexus, or some one who is 100% sure he/she knows wht tht sign means.
so if annnyyone knows please help!!
Pretty sure its the low oil level light, the low oil pressure light looks different I believe. Might want to check your dipstick. If you recently changed your oil and it's low already you also might want to see if you have any leaks.
Hope I helped.
Hope I helped.
"IGNORE THE CHECK ENGINE LIGHT" Famous last words.......
That light is the low oil level light. Either you didnt add enough oil, or need to fix the sensor in the oil pan.
Also, No AutoZone for a 93, Must be a 95 or above and OBDII for Autozone to scan it....
Check engine light codes are alot easer to check on these cars (OBD1).
Tools Needed:
A Paper Clip
The Key
thanx alot people...ok it must be a glitch in the oil sensor then, cuz the oil levels are ok..
- any one have a working link to the owners manual for a 93 es300..i cant seem to find the owners manual (i have the technical training manual).
- any one have a walk through or have an idea how to get to the oil sensor in the oil pan?
thanx alot again!
thanx alot again!
can anyone get back to my comment above?
also how about this: that symbol could mean that the oil temperature is rising etc?is that a possibility, or is that a different symbol?
