Sticky/gummy trunk button
Old 08-27-10, 05:05 PM
g26
g26's Avatar
Default Sticky/gummy trunk button
Hello all.... The trunk button on the back of my 07 ls460l seems to have "melted" in the South Florida heat. It is now a stcky black patch that feels gross when opening the trunk. I'm gonna have it looked at/replaced soon.
Has anyone out there encountered a similar problem?
Thanks
Old 08-27-10, 05:14 PM
305Busa
305Busa's Avatar
Wow, I have an 07 in Miami but havent had that problem as of yet. Sounds weird though. There are many more exterior plastic parts on the LS that would have experienced the same issue as the button if the heat was the issue. One example would be the plastic piece that the rear camera is mounted on.
Old 08-27-10, 05:36 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
a thread in 3gs forum
https://www.clublexus.com/forums/gs-...nd-sticky.html
Old 08-27-10, 06:22 PM
jmcraney
Forum Moderator
jmcraney's Avatar
I live in North TX and I have a 2007 LS460. It has the "gummy" trunk button too. It has been that way for a couple of years. I am fairly confident that it was not caused by exposure to some chemical as I am the only one who washes it. Nothing comes off on my fingers and it seems to be better in the Winter. None of the other parts on my car are exhibiting any unusual texture change or tackiness.
Old 08-28-10, 08:11 AM
g26
g26's Avatar
Thanks, At least I'm glad to see I'm not the only one with the issue -- freakish, strange thing. Every time i open the trunk from the back it is like pressing into chewed up gum... eeeeek.
Can't wait to get it changed, i wonder what the service rep will tell me... They always make subtle suggestions that the car is fine and the owner messed it up.. Probrably true sometimes but annoying none-the-less....
Old 08-29-10, 05:26 AM
bobp
bobp's Avatar
I'm in Houston, and I had the same problem - and found a simple solution.
Using a sandwich bag, I cut a square about the same size as the button (a little bit larger), applied it to the goo, and then tucked in the extra inside the metal edge around the button.
No more goo problem - and the button works fine.
Next time I take the car in for service, I'll ask them to look at it - but for now, no more goo fingers when opening the trunk...
Old 08-29-10, 06:09 AM
JFNash
JFNash's Avatar
That's weird.
Where I live the temperature hits 120 degrees during the day and has never been below 100 degrees for the past 5 months and I haven't noticed anything like that.
I wonder what the dealer will say about it when you report it to them.
Old 08-31-10, 10:20 AM
beun
beun's Avatar
I just noticed I seem to have something similar. The rubber feels sticky and it looks all cracked.
Old 09-01-10, 02:46 PM
JAXLS460
JAXLS460's Avatar
I see that all the time here at our dealership not just on LSs.
Old 09-04-10, 12:12 PM
g26
g26's Avatar
Is it an easy fix?
Old 09-04-10, 11:07 PM
Doubleg
Doubleg's Avatar
I have the same issue..and yes, I live in SFLA. Do you think it's covered under the warrantee?
Old 09-06-10, 07:17 PM
zzzzdoc
zzzzdoc's Avatar
I see Microsoft mouses develop that same issue indoors. Not sure what causes it. Don't think it's heat.
Old 09-16-10, 12:47 PM
bobp
bobp's Avatar
My LS is in the shop for 50K maintenance. Reported the trunk button problem - the dealer indicated they will replace it under warranty.
Old 09-18-10, 05:03 AM
jsmuve7
10th Gear
jsmuve7's Avatar
I'm in Charlotte, NC... Have the same problem. Just had 20k oil change at the dealer and forgot to mention it
Old 04-07-13, 05:08 PM
ihatekimch
ihatekimch's Avatar
I'm so glad I'm not the only one. Unfortunately for me, it is out of the warranty. Anyone did DIY on this issue. Thank you. ^ ^
Quick Reply: Sticky/gummy trunk button
