Maintenance Schedule
Old 05-09-10, 07:36 AM
jimmer!
jimmer!'s Avatar
Default Maintenance Schedule
I'm in an area of AZ that only has a Toyota dealer, so I've been
wary whether they know the actual maintenance schedule for
my '04 SC430.
I did some skunking around and found this Lexus.com source and schedule .pdf.
Not sure if it varies much for other model years,
but if you'd like to check here's the way to get a schedule
for your particular model years (have your vin number handy):
Go to lexus.com.
Click on Owners
Register your Sc430 using the Vehicle Identification Number found on your dashboard or door sill.
Once registered, click on "Service" from the drop down menu
Click on "View Maintenance Schedule
Then click on the .pdf link
This sign-up was quick and easy.
Reviewing my situation reveals that lots of these maintenance points have not been
performed per this schedule, but will be next time.
Hope this helps. jimmer
File Type: pdf
Old 05-09-10, 07:51 AM
scdroptop
Forum Moderator
scdroptop's Avatar
Thanks jimmer! Once again the www.lexus.com is a great resource for all sorts of things....recalls, maint history, maint schedule, volume library, warranty information, etc etc.
Oddly enough we found that some SC's suggested spark plug replacement intervals change and I believe trans fluid and coolant changes as well from some years.
Thanks for sharing!
Old 05-26-10, 03:10 AM
igorxx
igorxx's Avatar
I tried this and they just put me off.
Old 05-26-10, 06:05 AM
nkx1
nkx1's Avatar
What's up with the all the 'Re- Torque drive shaft flange bolts' recommendations? Does anyone actually have this done?
Old 05-26-10, 11:09 AM
jimmer!
jimmer!'s Avatar
you mean that you couldn't register your 430?
if so, wonder if it was a vin number typo on your part?
jasone36
01-12-12 12:08 PM
Addiction2
08-11-05 02:06 PM
bengreen
03-10-02 06:31 PM
Quick Reply: Maintenance Schedule
