Old 12-16-14, 12:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
DIY: IS350 Spark Plug Service
Old 05-22-10, 06:08 PM
javyLSU
2IS OG
javyLSU's Avatar
Exclamation DIY: IS350 Spark Plug Service
Lexus calls for changing the spark plugs at 60,000 on your IS350 - here's what you'll need to change the spark plugs on your IS350:
-10mm socket set with at least a 6 inch extender bar
-Spark plug socket
-A tiny bit of motor oil
-If have you a ratcheting wrench or a universal joint, it will very much come in handy.
-A 6-pack of your favorite beer
You'll need 6 spark plugs - I used the OEM Denso plugs, Lexus part # 90919-01249:
These plugs come pre-gapped, so if you're using the OEM Denso Iridium plugs DO NOT adjust the gap on these plugs.
First you'll want to remove all the engine covers, along with the air intake box assembly, air hose, and induction scoop.
This is what the engine bay should look like after removing everything. In the picture below, I'm pointing to one of the ignition coil tubes that we're going to remove a few steps later. Take your time and get familiar with what they look like and locate all 6 (3 on each side), because there will be a few harnesses in the way that will have to be loosened in order to remove the ignition coil assembly:
I started with the passenger side. There are a few 10mm nuts that are fastening a harness over the ignition tubes, partially blocking access. Remove them:
Next loosen the 10mm bolts fastening the tubes to the engine block.
Separate the harness from the ignition tube by pressing on the tab and pulling the two apart:
Pull the tubes upward and out.
You'll now be able to see the spark plug inside the shaft.
Now you'll need your spark plug socket with the 6" extender bar. The spark plug socket is a special deep socket that has rubber grommets inside that will grab the spark plug and let you remove it from inside the ignition shaft:
This is what the whole thing looks like:
You're going to need every bit of that extender bar to remove the plugs:
This was the first plug I removed (at 60,000 miles)
Apply a tiny bit of clean motor oil to the first three threads of the new spark plug to help avoid cross-threading the plugs. Be VERY CAREFUL installing the plugs - if you cross-thread the plugs, you now have a very big problem. Put the new plug into the same special spark plug socket tool you used to remove it, lower it into the shaft, and hand-tighten it once the plug finds the thread:
Use a torque wrench to tighten the spark plugs to 25 N*m (254 kgf*cm or 18 ft*lbf).
Reinstall the ignition coil tube, and repeat for the other 5 tubes. The bolts that fasten the ignition coil tubes to the engine block should be torqued to 10 N*m (102 kg*cfm, 7 ft*lbf). In other cars I've done this on, you had to make sure to do one plug at a time because you didn't want to connect the wrong ignition coil onto the wrong spark plug and foul up the firing sequence. On this car you can do as many as you want at the same time because the harnesses are just long enough to reach the intended plug - so no worries there.
Now on to the driver's side. This side will be a little more difficult as there are a few wiring harnesses that must be removed in order to gain access to the bolts that secure the ignition tubes. Start by removing these two nuts:
You can then lift the harness out of the way just enough to slip a box wrench (the ratcheting type will make your life a whole lot easier) behind and unfasten the ignition coil tube:
Remove or loosen any wiring harnesses that impede your access to the ignition coil tube bolts. The final bolt can be accessed from above with a little elbow grease:
Reinstall everything you just removed, and enjoy a (few) well deserved beer(s) for a job well done. You might want to take this opportunity to remind the significant other of your money-saving accomplishments. Make sure and let her know you just saved $300.
I hope you all find this useful!
Javier
The following 9 users liked this post by javyLSU:
93SCMax (03-03-17), jreancsu (10-06-20), kleepytime (08-11-21), Mrfix (12-18-16), Noeh (10-23-20), OPMWes (05-19-19), shadowmite (02-25-19), strikeraj (01-28-18), ZealIS (04-24-20) and 4 others liked this post. (Show less...)
Old 05-22-10, 07:41 PM
datplayaz
datplayaz's Avatar
Good write up Javy.. Thanks
Old 05-22-10, 07:51 PM
iSuxeL
iSuxeL's Avatar
Did mines a while ago. Thank god it's easier than the 250 LOL
Old 05-22-10, 08:33 PM
Pnuge88
Pnuge88's Avatar
i thought my DIY was much better.. just sayin.. hahaha jk great job javy!
Old 05-22-10, 09:14 PM
integlspwr
integlspwr's Avatar
oh **** i thought it was super drama to do this. i guess i have somethign to do in addition to my next oil change.
Old 05-22-10, 09:44 PM
albis350
albis350's Avatar
Damm thanks a million...I was a lil bit worried about this didnt want to pay the dealer to do it and was scared cuz i tought i had to take out the intake manifold and all that but I see thats on the 250....great news and awesome write up thankz again buddy
DannySC (07-14-18)
Old 05-22-10, 09:54 PM
mxis350
mxis350's Avatar
OHHH SWEEETTT!! Im at 55k and was starting to save the $300 bucks!! Now I will only need about $150 (need to buy the tools) But I get to keep the tools for other stuff so I will only lose on the spark plugs!!
Thanks!!!
Old 05-22-10, 11:19 PM
9relude8
9relude8's Avatar
thanks JAVY I really needed this LOL your awesome!
Old 05-23-10, 10:51 AM
edgeucated
edgeucated's Avatar
i just bookmarked this. thank you javy
Old 05-23-10, 02:03 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
Nice write-up Javy!!
Old 05-23-10, 02:06 PM
IS35O
IS35O's Avatar
Nice writeup, bookmarked for when I hit 60k
Old 05-23-10, 02:47 PM
rukkus2IS
rukkus2IS's Avatar
Is the process different for a 250?
Old 05-23-10, 04:46 PM
tC_demon
tC_demon's Avatar
Like the pics!...lol..Nice Write Up!
Old 05-23-10, 05:53 PM
gc86
gc86's Avatar
I remember reading about having to remove the intake manifold and all this other stuff. Is it possible to actually get the coil packs and plugs out without removing the previously mentioned?
Old 05-23-10, 06:18 PM
javyLSU
2IS OG
javyLSU's Avatar
Haha, your DIY was awesome! Thanks for putting it up, it's all about contributing to the community.
I didn't remove the intake manifold...
Javier
Quick Reply: DIY: IS350 Spark Plug Service
