Timing Belt or Chain
Old 03-02-10, 12:41 PM
vs1979
vs1979's Avatar
Default Timing Belt or Chain
Hi, just bought 2007 GX 470 and was wondering if it has a rubber belt or chain?
Currently have 79,000 miles on it
Thank you
Old 03-02-10, 02:29 PM
akfd
akfd's Avatar
I believe it's a timing chain.
Old 03-02-10, 04:16 PM
mansito
mansito's Avatar
Nope, timing belt. Belt needs replacement at around 90K miles.
Old 03-03-10, 12:08 PM
nbeihl
nbeihl's Avatar
Has anyone done the timing belt? How hard was it? I am a shade tree mechanic...
If not, how much was it to take in to the stealer?
Old 03-03-10, 06:31 PM
mansito
mansito's Avatar
Do a search on timing belt. There was thread about it. I believe it is about $1,200 at the dealer. I am a DIY, but that is a job I am planning to let the dealer do.
Old 03-04-10, 07:20 AM
STDave
STDave's Avatar
Wow, I dodged a bullet. My water pump was leaking and got down into the timing belt area. Sewell changed the timing belt for me under warranty while they were replacing the pump and radiator.
David
Old 03-04-10, 07:33 AM
3UZFTE
3UZFTE's Avatar
Timing belt, the next gen GX460 is the timing chain. The timing belt's aren't too hard because you have a fair amount of room to work with. With that being said, if your not comfortable with doing all the steps correctly, it's best to let someone else handle it. I think the hardest part for most people is getting the crack shaft bolt out.
Old 03-04-10, 09:11 AM
vs1979
vs1979's Avatar
Thank you all for your responses. Just got off my phone with Lexus and they said following: "Thank you for your patience while I researched your concern. Your vehicle is equipped with Timing Belt, the recommended time to replace it is at 90k or 108 months."
Old 03-04-10, 12:43 PM
mann777
mann777's Avatar
Where did you get this info about the V.belt, it only cost 88/.
Old 03-04-10, 05:10 PM
mansito
mansito's Avatar
I meant the whole replacement job (labor + parts, including water pump).
Old 03-05-10, 06:24 AM
mann777
mann777's Avatar
The 90K does not involve changing the Water pump unless it is bad, As per the Service chart, it is only the V-Belt. Inspection is done while changing of the V-Belt, if other related components are faulty, otherwise they are good to go. My friend just completed 90k having plats warranty, they only changed the V belt, as all rest was good. Also changing the VBelt is max 15minutes job. Basic tools required to install the serpentine belt.
Old 03-06-10, 02:45 PM
mansito
mansito's Avatar
Nice to know. Thanks for clarifying. I thought I read a post you wrote about changing the timing, and it seemed complicated. I could be wrong. Maybe I'll give it a try when the time comes.
Old 03-17-10, 07:47 AM
sphy1005
sphy1005's Avatar
my quote at the dealer was over 700 for the t-belt package (water pump etc...) and about 500 for the 90k. Which would be around 1200.
If you're pretty handy then it shouldn't be a problem doing it yourself
Old 03-17-10, 11:50 AM
97JZA80
97JZA80's Avatar
Hopefully a future owner here....Ive done one on a 4.7 tundra so same motor and it wasnt a big deal. Obviously a few things will be different with the GX but shouldnt be too much different.
And do the water pump too if your there, no sense in going in that far and not doing it.
Old 03-17-10, 02:54 PM
mansito
mansito's Avatar
Looks like a nice Supra. Please post some pics. I think it should be OK, also made by Toyota.
Quick Reply: Timing Belt or Chain
