Oil Maintenance Required Warning Light
Old 02-14-10, 12:42 PM
lrosen3565
lrosen3565's Avatar
Default Oil Maintenance Required Warning Light
What is the procedure for resetting the Oil Maintenance Required Warning Light on the 2007 Lexus LS-460? The vehicle has keyless ignition.
Old 02-14-10, 03:43 PM
jstjohnz
jstjohnz's Avatar
1. Make sure your trip odometer is on Trip A.
2. With the car turned off, press and hold the "Reset" button for the trip odo.
3. Foot off the brake, press the start button twice while holding the reset button and wait for it to reset.
Parrokeete (12-11-21)
Old 02-14-10, 06:53 PM
lrosen3565
lrosen3565's Avatar
Many thanks......worked like a charm
Old 02-15-10, 08:14 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Owners manual is a wealth of info too!
Old 07-28-10, 08:20 AM
ZachTax
ZachTax's Avatar
VERY HELPFUL!!! Thanks!
Old 08-17-10, 08:43 AM
venny1
venny1's Avatar
Default LS 460 rest oil maintenance light
Excellent answer & now for question.
If due to highway driving you exceed the 5k limit for oil change. Example - you exceed the 40k oil change by 1.8k & odometer reads 41.8k when oil changed. Will next oil change warning come at 45k or 46.8k?
Thanks venny1
Old 10-01-10, 06:33 AM
tpuig
tpuig's Avatar
Just did this, thanks!
Old 10-01-10, 12:15 PM
Craig B
Craig B's Avatar
Thanks venny1
No, once it's reset, that will be 5,000 miles, or 6 months from the time you reset it...
Old 10-01-10, 11:45 PM
tpuig
tpuig's Avatar
I was wondering about the 6 months. We bought a car CPO and it sat for a couple months. About a week after we picked it up, the change oil light came on. Didn't think it was due to mileage...
Old 10-02-10, 02:16 AM
Craig B
Craig B's Avatar
I would take it back to the dealer and ask for a no charge oil change...
Old 01-16-13, 06:58 PM
LexVoitek
LexVoitek's Avatar
Exclamation Reset Oil Maintenance Required Light on Lexus LS-460
The instructions sound very similar to Resetting the 2010 Lexus ES350 Oil Maintenance Required Light.
See this how-to video
If that doesn't work,
try the 2006 Lexus GS Oil Reset Procedure in this video
Old 01-17-13, 09:37 AM
RandyV
RandyV's Avatar
Good timing on this topic as my light just came on.
When using synthetic oil, the 5K change interval is overly conservative - 8-10K is more reasonable based on documented testing in a myriad of vehicle types.
Any ideas on how extended oil change intervals impact an extended warranty?
Also, what's a good price for an oil change? The Lexus Dealer here has quoted $170!
Old 01-17-13, 04:53 PM
Nospinzone
Forum Moderator
Nospinzone's Avatar
On a 2007 LS you are OK with 10K oil changes using synthetic. My dealer charges $130 for a synthetic oil and filter change. (Note: I only take it to the dealer because I am working off a $500 credit I received for the VSR recall.)
Old 01-18-13, 12:51 PM
daryll40
daryll40's Avatar
In theory, I agree that 10k oil changes with synthetic SHOULD be ok. In reality Toyota DID issue some notices that SOME of their cars with 5000 oil change intervals can go 10K with synthetic. The LS460 specifically IS NOT one of them.
Old 02-16-14, 03:02 PM
Carnut
Carnut's Avatar
Default Owners Manual
It sure is if you have a couple hours to find what you are looking for. It's easier to GOOGLE what you want to do and it usually takes you right here to this forum to give you a quck answer.
Quick Reply: Oil Maintenance Required Warning Light
