Suspension Springs, shocks, coilovers, sways, braces, etc.
Tein edfc
Old 12-19-09, 12:32 AM
alwayzspeedin
alwayzspeedin's Avatar
Default Tein edfc
so i just got my tein edfc and i was wondering where did others mount the controller , i want a clean look and does anyone have the install guide...i know how to do the physical install, but i need to know the setup install guide?
Old 12-19-09, 05:50 AM
passnu2
passnu2's Avatar
The 2gen IS owners where putting it where the ash tray / outlet is located.
Old 12-19-09, 02:09 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
i have seen it done in the ashtray area too on the gs
Old 12-19-09, 09:05 PM
I8ABMR
I8ABMR's Avatar
If you mount it in the ash tray it should fit perfect. I have mine mounted in the console compartment for a stock look. It depends what you want. Clean look to the interior ( not that its a florescent yellow box) or easier access to the unit.
Old 12-19-09, 09:53 PM
alwayzspeedin
yeah i saaw how yours in mounted i think i am going to try to install it in to the ash tray remove my ash tray
Old 12-20-09, 12:27 AM
I8ABMR
I8ABMR's Avatar
I think I was talking to another member who said to get the box mounted in the ash tray he had a to cut a small hole in the AC vent pipe that runs the AC to the back seat area. Thats actually why I went with it in the console
Attached Thumbnails Tein edfc-img_0006.jpg   Tein edfc-img_0002.jpg   Tein edfc-img_0003.jpg
Old 12-20-09, 12:41 AM
I8ABMR
I8ABMR's Avatar
did a little leg work and found the other members pic. I hope this helps
Old 03-28-10, 11:06 AM
TWong350
TWong350's Avatar
Would you guys say that the EDFC is worth it? How often do you find yourself changing the settings?
Old 03-28-10, 01:10 PM
alwayzspeedin
did mines just like that...but i couldnt get it to go far enough down to close the door how i like it...the rear vent tube blocks it...do you remember whos car this is so i can pm that person thanx
Old 03-28-10, 01:18 PM
alwayzspeedin
Old 03-28-10, 04:52 PM
I8ABMR
I8ABMR's Avatar
I was talking to a member when I had mine installed and he had his in the ash tray but said he had to have the AC ducting to the rear seat cut so he could get it to sit flush with the console. Thats actually the main reason I had it installed in the arm rest
Old 03-28-10, 04:53 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
at least the unit will never overheat
Old 03-28-10, 05:03 PM
I8ABMR
I8ABMR's Avatar
you're right. I have had mine in the arm rest for 2 summers and have had no issues........so far. I love the EDFC, especially now with a pregnant wife. When my wife is in the car I will set the suspension to 15 from full hard (16 is max softness) and when I want to play or push her through some corners I set it to 3 front and rear. I am happy that I decided to get the full set up. It makes the entire system so functional and dynamic
Old 03-28-10, 06:40 PM
alwayzspeedin
damn i was hopping i didnt need to cut it..i was thinking of taking it out and heating it up witht a heat gun try to shape it { put a dent in it **
smokyis350
07-25-08 11:42 PM
SaddleLex
Suspension and Brakes
36
01-30-08 12:22 PM
07IS350
07-11-07 07:12 PM
SnoopyBQ
07-15-06 01:35 PM
Quick Reply: Tein edfc
