Hey guys if you want to SeaFoam and you feel it works great, go right ahead. I have no problem with that at all. I was just pointing out that you can mix up your own can size "Seafoam" home brew treatment in about 5 minutes with approx 50 cents worth of the absolutely identical materials (readily available from Home Depot). The actual formula is by weight but this would easily be close enough - mix approximately 5 oz Mineral oil, 3.5 oz Naptha, and 1.5 oz rubbing alcohol - presto... a 10 oz 50 cent Seafoam treatment.
btw - The 128 oz size Seafoam lists for $69. That's a pretty cool markup they got going.
that's like saying, Dr Pepper is just carbonated water, high frutcose corn syrup, some coloring, phosphoric acid and a few other things, only 12 cents worth of ingredients. why not make your own?
after all, a can of seafoam is only about $5 (give or take a few bucks). not exactly draining my 401k (if I had one).
I understand where you are going with the Dr Pepper comparison and it is a good point. There is a convenience factor involved. Dr Pepper may not be the best example because I don't have high fructose corn syrup, coloring, and phosphoric acid, or "a few other things" sitting around my house. And more importantly I do not have access to he formula for mixing of Dr Pepper. The ingredients formula for the Seafoam product is available. And I do have rubbing alcohol, mineral oil (we use it for treating wooden surfaces) and Naptha - (aka lighter fluid) sitting around my house. Seafoam sells for about $6.50 for 16 oz but again , good point for $6.50 a can there is time saving and convienience in just buying it ready made. I just wanted folks to realize what was in it - there are no "special secret ingredients or some space age complex formula".
Dr. Pepper and all other Cola's get their flavor (aside from sweet) from a very specific mix of essential oils that you can't just get and mix properly without lab equipment. That is a red-herring.
What I use instead of SeaFoam is intake cleaner. Some state they are catalytic converter safe if you are worried. I spray about a third of the can on the throttle-body and use a toothbrush to remove the buildup around the edge of the butterfly valve if it doesn't come off with just spraying. I start the car and it cranks for a while before it will run without throttle added. Then I have a helper run the motor under 3k rpm while I spray the rest of the can directly into the throttle body. White smoke etc is involved, as is improved off-idle performance. This has made a significant difference each time I have done it (60k + miles on each vehicle).
I don't add things to my motor-oil but I do use MoPar Fuel-injector cleaner or Techron fuel additives. A friend was told in his ASE classes those are the only fuel additives that work well. I have had improved mileage and performance improvements as well.
I have changed the oil several times since Ive had it and the usual 3000 - 3500 miles had the dark brown used oil look to it. This time however the oil was black, I mean BLACK. As far as the temp gauge not a drop that would cause an eyepop but a general "running a tad bit cooler" of the engine in general. Im not trying to start a heated debate but I havent torn up my ride, (LOLOL) and I got a little better performance. call me crazy, lol.
I'm thinking about running some seafoam through my system. I just got over 150K miles and have noticed a pause in power around second gear when taking off from a light. It pauses slightly for a few seconds and then goes back to normal power. I thought it couldn't hurt to give it a try, snake oil or not.
