SRT intake with Borla exhaust DYNO test results
OK - Here is the scoop.
I bought my GS430 brand new on December 2nd. This month I had the car DYNO tested with no mods and got 235 RWHP and 252 RWTorque. I put on the Borla exhaust and Dyno'd the car again. I got no increase, actually less than 1/2 RWHP. I added the SRT intake and ECU and WOW!!!!!!!!!! I had the car DYNO tested and got 262 RWHP and 287 RWTorque, an increase of 27 RWHP and 35 lb-ft or torque.
The car sounds great, like a sports car should and when I step on it WOW, she sounds GRRRRREAT and gets it up in a hurry. Now I have the sporty luxury sedan that I wanted.
P.S. My wife thinks it's sexy - you know what that means!
Lovin' life!
Lovin' life!
Re: SRT intake with Borla exhaust DYNO test results
Lovin' life!
Lovin' life!
Watch out for those cops
Northern California Regional Officer
That's a great improvment.
I would of been curious to find out if the Borla's contributed to part of the increased power you now have, if you had instead done the dyno, doing the intake mod first and the exhaust mod second. Usually you need to improve breathing, as well as exhaust to reap the full benefit at both ends.
Dyno Tests
Yes I think that you are right. I wanted to do the SRT first, but the exhaust came in first and I just couldn't wait. I think that some of the increase did come from the exhaust, but I am not going to put the stock pipes back on and re-test it. Oh well - need a radar detector now - big time.
What were the weather conditions (barometric pressure, temperature, relative humidity) during the dyno tests:
1. stock
2. with borla
3. with borla and srt intake
Was the torque converter locked during all three dyno tests?
1. stock
2. with borla
Well I have the same setup and when I had my car dyno'ed at SRT the weather was 90 or so and very humid. Best my car could put out that day was 255 RWHP. Now that I see Marcianof put out 262 RWHP, I would assume the weather was a lot better, hence the almost 10 HP difference. So weather will play a role of sorts when dyno'ing a car.
An aftermarket exhaust (non-cat types) will not give you a lot of benefit until you open up the stock intake. With only the aftermarket exhaust, you are allowing more exhaust to flow OUT your system, but so what???, your system is still sucking the same stock amount of air using the stock intake. By getting the aftermarket intake WITH the aftermarket exhaust, you are opening up both ends (more air IN and more exhaust OUT), thus great a real increase in HP. IMHO
Originally Posted by jskim9
ambient temp and humidity makes a huge difference in engine performance. How much depends on the engine of course. I know for the Mustang 5.0 engine, bone stock, every 10 degree made about 3-4 HP difference (I read it in a Muscle Mustang & Fast Fords article - they checked on a chasis dyno). But of course, elevation makes the biggest difference.
I feel like I should remind people though that your DYNO print-outs *should* all be in a 'corrected' format. This means, altitude correction, humidity and temperature correction.
Basically, your dyno charts should be apples to apples IF the dyno operator set up their machine properly for elevation/location adjustments. You can get your printout in either non-corrected, or corrected mode, but most should be in 'corrected mode'.
That being said, I don't see 10hp difference between 2 same model cars as being too much, especially with different dyno's.
Different dyno's will give you a different reading almost every time. There can easily be a 3%-5% variance between different Dyno's. In testing, as long as you use the same shop before and after a change, you're good to go.
