90k Serivce - Timing Belt and Water Pump
I have been searching around and I have the part numbers for the timing belt, water pump, o-rings, and the coolant for a TB/WP change. I noticed people are replacing the cam (2) and crank (1) seals as well. I can't find for the life of me the P/N's for them.
What else is recommended to change/replace on this service? I plan to do the service here soon after I change out the balljoints because the previous owner has put it off for ~20k miles after the dealer told her she should replace them from being worn out.
TIA.
I sent this to another member last week because I'm changing my timing belt/water pump today...
I have a '98 GS 300 and bought parts to do the timing belt/water pump replacement. These should be Toyota/Lexus part numbers...
#13568-49036 Timing belt
#13505-46041 Idler, T/B
#13540-46030 Tensioner
#90210-26002 Washer
#90311-40020 (2) Oil seal
#90311-46001 Oil seal
#16100-49876-83 Pump assembly
#90916-03093 Thermostat
#16325-62010 Gasket for thermostat
#96761-24022 (2) O-Ring
#96761-24028 O-Ring
#99366-D1930 V-Belt
Parts w/ tax came out to $502.61. Now I gotta find a reputable shop to do the repair.
Hope this helps.
#90210-26002 Washer
#96761-24028 O-Ring
#99366-D1930 V-Belt
Hope this helps.
If you need help on your timing belt let me know. I have all the special service tools from Toyota to do the job. The crank pulley bolt you will DEFINATELY have fun on without my crank pulley tool
I also have airtools to make everything go faster with less effort.
#90210-26002 Washer
#96761-24028 O-Ring
#99366-D1930 V-Belt
Hope this helps.
#90210-26002 Washer
#96761-24028 O-Ring
#99366-D1930 V-Belt
Hope this helps.
#90210-26002 Washer
#96761-24028 O-Ring
#99366-D1930 V-Belt
Hope this helps.
Thanks!
