no u wont need it since your not gonna be super dump.. rolling on stocks, 17-20 wheels? but for the front RCA would def help a bit... just put your toe into spec and that shud save u some tire wear
2-2.5" isn't crazy low at all so you should be okay as long as your toe is fine. Camber just wears one side more than the other. If you can't rotate/flip your tires, then I would definitely invest in some RCAs. The amount of tire you save will eventually pay for the RCAs.
Any suggestion in regards to wheel spacers? I am planning on 245/40/18 on 8x18 for the summer and ugghh, the stock 225/55/16 on 16x7 for my winter setup...
Don't want to be too aggressive just not sure what these two wheel/rim setups will look like without spacers...
right now stock they are so much inside I cringe at the thought of what the 16's will look like with the megans...
im going to get some megan coilovers this weekend and im going to slam my car im on stock wheel but i was wondering if anyone had any suggestions for what size spacers would look good and somewhat flush
