My first Lexus 2007 GS350 w/ ML
I've been scoping Club Lexus here for several months and picked up some F-Sport parts back in July when there was still a discount (Exhaust, Intake, Springs and Sways). Yesterday, I put on the F-Sport exhaust and intake and all I can say is WOW...Since it was made by Lexus, I did not expect much noise, and you really don't hear too much when the windows are up...but with windows down around 6-7K RPM, it gets really really loud (noticeably loud). At cruising highway speeds of 75-80 MPH, you hear a light droning especially if you are using cruise control up and down slopes.
I am very happy with how the GS rides and definitely don't want to compromise its suspension so I will more than likely be looking to sell the F-Sport Springs (w/ Tein silencers included for Front and Rear to help reduce any noise) brand new, and unopened with packing slip still attached for $250 (saves you tax, shipping, and you get free silencers) to anybody interested in the Dallas/Fort Worth area over Thanksgiving break.
I do plan on installing the F-Sport sways, but only when the newly redesigned bushings are released for the Front sway because I would die if my car made knocking noises.
I have yet to install the Scosche Ipod Adapter for 2004-up Lexus and will hopefully get it done here today or tomorrow; I also purchased the rocker switch that was recommended by a Club Lexus member from drillspot to override the Nav functionality while driving and will also be doing that MOD at the same time.
One last question I have is for those who have had problems with their passenger side HID lamp. I've ordered OEM Philips 4300K D4S replacements from ebay for $79 shipped for the set. I'm hoping that this will correct the problem and restore lighting.
My problem started when I pulled into the garage Saturday night and the right lamp went out. I then turned off the lights and turned them back on. According to the reflection, the passenger lamp initially lights up for maybe 2 seconds and turns off. I'm hoping that it is not the ballast and in fact, I have no idea how to get to the bulbs to swap them and Lexus sure gives little to no instructions as to replacing them.
For those who have swapped out their HID bulbs, do you just turn your tire and go through the plastic sidewall cover above the tire and behind the headlight assembly?
you turn the wheel and go through plastic well only for the fog light replacement..
so do i go through the plastic for both the low beams and fog lights?
I also received shipment of the D4S phillips 4300's and swapped out both bulbs. Turns out that my ballast is perfectly fine (knock on wood) and that it was just the passenger bulb that was near term.
