Rx330 Brake Pads replacement
Old Nov 3, 2009 | 11:05 AM
  #91
mandyfig's Avatar
mandyfig
For me...very tight and tight.
Old Nov 4, 2009 | 06:46 AM
  #92
968racer's Avatar
968racer
Originally Posted by tromly
+1, wonder if the stealership does this when they test drive the car ?? My service advisor never mentioned it to me
There's no way the dealer would bed the brakes. I take my cars on a country road where there's no traffic. Some people may not have this luxury. It's really fun to do and puts a smile on my face. Be sure you don't have any loose cargo that can fly forward as you're mashing on the brakes.
Old Nov 4, 2009 | 06:47 AM
  #93
968racer's Avatar
968racer
+1 Never had one loosen up.
Old Nov 4, 2009 | 12:49 PM
  #94
mandyfig's Avatar
mandyfig
Really like them tight. But sometimes you have to let go a bit!
Old Nov 6, 2009 | 11:47 AM
  #95
968racer's Avatar
968racer
I also keep in mind that the next time I change them that I don't want to be busting my knuckles or pounding on the wrench to break them free. I try to remember to put some anti-freeze compound on the bolts too.
Old Nov 7, 2009 | 07:12 PM
  #96
LEXEHAM's Avatar
LEXEHAM
Default Great Thread
I changed my rear pads today, with the help from this forum. The job took about one hour. I ordered the parts from Sewell and I included the fit kit but not the shim kit. I have a 2005 with 68K. Thanks Mandyfig for your excellent posts.
Old Nov 8, 2009 | 04:49 AM
  #97
mandyfig's Avatar
mandyfig
Yes, anti-seize is your friend.
  #98
mandyfig's Avatar
mandyfig
You are welcome, just giving back. Have learned a ton from this forum!
Old Nov 14, 2009 | 05:55 AM
  #99
biff44's Avatar
biff44
You do not have to go nuts doing this. All you are doing is heating the brakes up to drive out any solvents and prevent them from glazing from your first panic stop. Just go out and drive 30 mph with the brakes draging. After they heat up sufficiently, let them cool down. Then do it again. You can do it in city driving.
Old Nov 14, 2009 | 09:16 AM
  #100
mandyfig's Avatar
mandyfig
Bedding, from what I understand is for high performance, heavy duty braking. The stop and go type. Mainly for commercial use.
If you are just making sure that the solvent and/or sealer is off the steel, as recommended above should be fine right?
Old Nov 16, 2009 | 01:09 PM
  #101
968racer's Avatar
968racer
You're also transfering a small layer of pad to the rotor. If driving the resins out was the only objective, this would eventually be done on normal braking. To get the most out of your brakes, bedding should be done.
Old Nov 16, 2009 | 01:11 PM
  #102
968racer's Avatar
968racer
Yes, it is used much more commonly on high performance vehicles but can be beneficial for all cars with new rotors & pads.
Old Nov 28, 2009 | 11:03 AM
  #103
andrewr's Avatar
andrewr
Default replaced front pads
I just replaced the front pads and this diy was very helpful. Here are some notes:
After removing the wheel, I stared at the pad assembly for some time, not realizing how to remove the pad. Finally I wedged a screwdriver between the pad and rotor and gently pried it out.
I didn't have the correct socket for the lug nuts, so I couldn't torque them properly. We are getting the tires done today, so not an issue. Anyone know the socket size?
Thanks to Pohanka (dealer), the brake fluid was well over the max line, so I had to remove quite a bit. Anyone know how to properly dispose of this stuff?
I used a c-clamp to compress the caliper piston. This worked ok but I was concerned about how the rubber seal had bunched up.
I put some anti-squeal lube between the shims and pad. I assumed this is where it is supposed to go, as opposed to on the shim, which was dry.
Getting the clip onto the inner pad was a little tricky.
I used the car jack to raise the car. Piece of cake. Was going to use my fancy hydraulic jack but I couldn't find a good place to put the safety stands and you can't leave a hydraulic under load.
Overall, an easy job and saved $300 over what toyota was charging. Hate to know how much lexus charges.
Old Feb 17, 2010 | 05:39 PM
  #104
mandyfig's Avatar
mandyfig
Just to remind some people that there is this DIY.
Old May 2, 2010 | 09:39 AM
  #105
jjwalker's Avatar
jjwalker
Big Thanks to mandyfig.
Just did the wife's 330 front brakes everything went smoothly. Did not turn or replace the rotors though, car only has 37k on it and there are no grooves or a pulsating pedal.
Thanks again!
