For those with JoeZ Intake...
Old Nov 5, 2009 | 06:54 PM
UT-ISF's Avatar
UT-ISF
Registered User
Default For those with JoeZ Intake...
Since it retains the stock airbox, is there any difference in sound?
Also, would it be possible to put a cone filter on the JoeZ tube, remove the stock airbox, and create some sort of heat barrier/shield. I like the concept of the K&N, but I do not want a "Greasy" filter messing up my car.
Brandon
Old Nov 5, 2009 | 09:26 PM
batdude's Avatar
batdude
i have never liked K&N products for exactly that reason
all i know is that with the Joe-Z intake, my kids can hear me coming towards the house about 1/2 mile from the front door.
yes, i drive my car like it's meant to be driven....
even in colorado.
i'm going for the *CSP record on # of reports called in.
LOL
d
Old Nov 5, 2009 | 09:32 PM
malujerry's Avatar
malujerry
keep the stock box for heat shielding, drop in a tom's filter
Old Nov 5, 2009 | 10:08 PM
MicaISF's Avatar
MicaISF
Brandon
i thought about doing similar set up with stock intake. the stock intake is ~ 3 1/4 inches which is very similar to the stock honda s2000 cone filter. it might just fit fine. i will give it a try next weekend when i am not as busy. i will also measure to see which filter has more filter area.
Old Nov 6, 2009 | 05:19 AM
flowrider's Avatar
flowrider
Veteran: Air Force
I've got the JoeZ with a K&N dropin. Been on for over 7K miles with no issues.
Lou
Old Nov 6, 2009 | 06:40 AM
btwanky's Avatar
btwanky
where can you find the toms air intake?
Old Nov 6, 2009 | 08:34 AM
malujerry's Avatar
malujerry
http://www.vipautosalon.com/front.php or maybe even http://www.l-tunedparts.com/index.php?id=140
Old Nov 6, 2009 | 09:37 AM
PHXF's Avatar
PHXF
Brandon
So, here's the thing. K&N's filter comes pre-oiled and ready for install. It's not greasy at all. If a K&N ever gets greasy, it is because someone over-oiled it after cleaning.
I have had zero issues with my K&N intake...unless you consider that awesome sound to be a problem.
Old Nov 6, 2009 | 10:11 AM
jaslapp1's Avatar
jaslapp1
K&N has power loss in the mid range and people are running worse times with them. Stick with the JOE Z intake tube and TOM's insert.
Old Nov 6, 2009 | 03:14 PM
j8123's Avatar
j8123
+1 I have had only bad luck with K&N product over the years. I will never purchase another intake from them or a drop in filter for that matter.
Old Nov 6, 2009 | 08:09 PM
verals05's Avatar
verals05
Performance - JoeZ
Sound - K&N.
I chose the JoeZ, because of performance also I wanted to keep the Dual Intake setup.
Old Nov 7, 2009 | 08:09 AM
FNMUPN8's Avatar
FNMUPN8
Keep the stock airbox, use a drop in if you feel you need to. The Joe Z gives you a nice increase in engine note at a lower rpm then stock. It sounds great mated up with an after-market exhaust. And it sounds really great on those cool, non-humid days which I am finally getting to experience in FL! Luv it!
Old Nov 7, 2009 | 09:24 AM
hwy1isf's Avatar
hwy1isf
I have the Joez intake and exhaust and I think the combination works well together. I am very happy with the sound and the performance.
Old Nov 7, 2009 | 10:34 AM
fleadog99's Avatar
fleadog99
I currently have the K&N CAI. I think it sounds more aggressive than the joe-z. I am verry happy with it, and also got it super cheap from autoanything. I am talking to a friend of mine who does some tig welding. He asked me If I wanted an exhaust and intake. He would put a pipe down near the front bumper. He said I may have to cut a hole to allow the pipe to go through. He is also going to fab me an exhaust. I will let you know how it goes, he went to SEMA so will be back soon.
Old Nov 7, 2009 | 10:34 PM
ExclusivIS's Avatar
ExclusivIS
Funny you say that, because I have noticed since the temp dropped cooler in NY my cars been responding a bit better, seems to be holding gears longer. Pretty cool. Love my JZ Exhaust/intake combo! The intake opened up a bit more sound to the whole exhaust note more so around the lower rpms.
