Ferrari 458 Italia First Drive ...
Old Nov 4, 2009 | 10:58 PM
Gojirra99's Avatar
Gojirra99
Default Ferrari 458 Italia First Drive ...
First Drive
Ferrari 458 Italia
Test date 02 November 2009 Price as tested TBA
Even in mixed conditions, you can still enjoy yourself without fear of a trip to the scenery
What is it?
The 458 Italia is the replacement for the F430. Although the basic configuration sticks to established principles i.e an aluminium space-frame and mid mounted V8 powering the rear wheels, much of the 458 is entirely new.
For starters, the engine is a 4.5-litre direct injection V8, related to that in California, but larger, producing much more power (562bhp) and revving higher (9000rpm).
And like the California the power is channeled to the road through a seven-speed twin-clutch gearbox, albeit with different ratios.
What’s it like?
At first relatively civilised, the idle smooth and calm. It’ll get you noticed, but it’s no hell raiser. However, like most modern performance cars, the 458 has trick exhaust by-pass flaps, so there’s a good chance with revs and throttle it will be more boisterous.
Metres is all it takes to register the first significant dynamic step change over the 458’s predecessor. The steering is much quicker. 2.0 turns lock to lock quick, and that considering a very reasonable turning circle.
The next thought, is how well the gearbox works, especially in the very ordinary roll of manoeuvring the 458 in traffic. Up in the hills though, I’m keen to explore whether a twin-clutch gearbox can deliver the sense of occasion and drama expected of a 200mph+ Ferrari.
To an extent it is a personal choice, and depends on whether you feel the jolt you get with a super-fast single clutch transmission - such as that fitted to the 430 Scuderia - to be a highlight or deficiency. Certainly the 458’s DCT is much smoother and faster than the F1 box, and yet, in my opinion, feels no less mechanical.
The gearbox is also well matched to the engine character, not only in its speed of reaction, but also its exactness. To get a handle on how much quicker the 458 is than the F430 you need to look not only at the jump in outright power (70bhp), but also where the power (and torque) is produced.
From 3500rpm the 458’s engine is already producing as much torque as the F430’s and at 6500rpm has eclipsed its peak power. This is a Ferrari V8 even more zingy and soulful than before, but now with added mid-range punch. To boot, it’s cleaner and leaner than the old 4.3.
Over the last 2000rpm, the energy and vigour is massively addictive. As is the noise. Any concerns over the timid idle have long since vanished, the 458 soundtrack not only ridiculously loud, but varied and with that shrillness only a flat crank Ferrari V8 can.
If there is a downside, it is that that on the road there are precious few opportunities to use all 458’s performance. Even in Italy. If you’re lucky you’ll see all of second gear, and occasionally third, but, such is the extent of the rev range and force of 562bhp, by then you’re really travelling.
More so than the styling, or engine performance, the one component that describes the biggest advance over the old car, is the confidence you get in 458’s front end. And this not simply a matter of more outright grip, but more consistency and better communication.
Apparently this transformation comes mostly from improvements in the rear multi-link suspension. By better controlling the camber angle and wheel centre movement, Ferrari has been able to increase roll stiffness and run faster more precise steering. And what of that quicker steering?
It takes a little getting used, but only in that it feels foreign to make such small movements (you only need move your hands for the tightest hairpins). But soon enough you find yourself intuitively applying the correct amount of lock in a single application.
Such that you can drive the 458 even in mixed conditions and still enjoy yourself, without fear of a trip to the scenery. Leave the Manettino in ‘low-grip’ or ‘normal’ and the electronics will keep things tidy, switch to ‘race’ and it lets the back slide a little wide under power. But it is testament to the predictability, steering accuracy and throttle response that the last two modes (‘traction off’ and ’you’re on your own’) aren’t completely off the menu.
Given the California exists to offer a more comfort orientated Ferrari, you might expect 458 to be ask more compromises than its predecessor. It doesn’t. Road and wind noise are very acceptable, and the ride calm.
As with the 430 Scuderia it is possible to decouple the suspension settings from the Manettino groupings, but even in the firmer settings the ride is far from jittery.
The interior is also a significant step forward. There is now a consistent quality (including two TFT colour screens), plus some genuine innovation. Ferrari has done away with the indicator stalks, putting the signals, light and wiper controls on the steering wheel. Not everyone will like it, but I think it works well.
Should I buy one?
If you can run to the estimated £160,000 Ferrari is asking, there are few reasons not to. The price may be higher than the old F430, but the 458 is a much more complete package. Not only faster, but more accomplished and more entertaining.
Jamie Corstorphine
http://www.autocar.co.uk/CarReviews/...Italia/244657/
Old Nov 4, 2009 | 11:01 PM
Rash's Avatar
Rash
hmm
In a second I thought it was a Dubai plate number, code L is kinda new.
Old Nov 4, 2009 | 11:31 PM
metalgear's Avatar
metalgear
not really liking those long head lights
Old Nov 4, 2009 | 11:36 PM
Oleg400's Avatar
Oleg400
The nose is hideous...The whole front is fugly.
Old Nov 4, 2009 | 11:37 PM
GS wanted's Avatar
GS wanted
...not a fan. especially at that price tag.
Old Nov 5, 2009 | 10:31 AM
UDel's Avatar
UDel
It would look much nicer if the front lower black inlet area was painted red like the rest of the car and if they used 4 tail lights instead of 2. Still the performance on this car will be unreal.
Old Nov 5, 2009 | 10:51 AM
1993ES300x's Avatar
1993ES300x
when i first saw a picture of this car it did not look like that.. the hood is stupid looking.. this car doesn't have the same eye candy as the older version.....
Old Nov 5, 2009 | 01:23 PM
I8ABMR's Avatar
I8ABMR
They didnt design a looker when they designed the 458. Its headlights are strange, the rear is strange, and I cant stand the black slits below the line of the hood. It makes the car look like its driven around with the hood popped open. I have a feeling the will have to "refresh" these design cues out to sell them like the popular 430. The 430 imho is flawless
Old Nov 5, 2009 | 01:24 PM
I8ABMR's Avatar
I8ABMR
who's brilliant idea was it to test drive a RWD car with 550+ hp in the rain. Brilliant!!
Old Nov 5, 2009 | 01:41 PM
TwiBlueG35's Avatar
TwiBlueG35
Both 360 Modena and F430 are much better looking than this new one.
Old Nov 5, 2009 | 02:50 PM
MPLexus301's Avatar
MPLexus301
As I have said since the pics of this car came out- IT'S UGLY. This thing has lost the beauty that every Ferrari is supposed to possess. It looks like a down syndrome cockroach from the front and the rear is ridiculously bland.
Old Nov 5, 2009 | 03:29 PM
kit cat's Avatar
kit cat
wait, so not even an option of the 3rd pedal?
Old Nov 5, 2009 | 04:15 PM
absolutely love it.
Old Nov 5, 2009 | 04:40 PM
TRDFantasy's Avatar
TRDFantasy
The dual-clutch transmission is the only option, correct.
Old Nov 5, 2009 | 07:11 PM
Faymester's Avatar
Faymester
Not seeing a good angle on that one.
