i was visiting a buddy's shop yesterday that only does lsx stuff. His extra cab truck runs high 10's on a cam and 200 shot of nitrous. I was having him weld some aluminum for my gs' radiator setup. I told him about this kit, he says i should do it. Looks like we're building a 6.0 ls2 stroking it to a 408 for my sts turbo silverado, but now maybe for the gs?
yup im gonna start one once i get some more stuff. the ls1 i just got is a long block. i got it for a steal ($700 lol) its missing a few things but i work at a chevy dealer parts department so i get a great discount.
also i just found a t56 for a great deal as well ($1200 with a z06 clutch and flyweel) so i should be getting started soon. its my daily driver so if i dont get everything aquired during the holidays the swap will have to wait til spring time since im still in school
1. Did you replace the Lexus drive by wire setup for the LS1 set up or did you use a cable? The LS motor is a drive by wire, with its own pedal or throttle position sensor correct?
2. With the eng/tran mounts, does the T-56 shifter come right up through the existing shifter hole with no persuasion? Supra Master cyl with Camaro
slave cyl?
3. How much was the drive shaft?
4. Any unforeseen issues like oil filter access, exhaust manifold clearance, hood to intake manifold clearance?
slave cyl?
5. steering shaft in the way ?
thanks again
j
1) LS1 Cable throttle body
2a) See page 2
2b) 3/4 wilwood master/ Internal slave
3) Call for pricing
4) Nothing unforseen, we assumed nothing. You will have to have some custom work done, or do a good amount of research.
5) Of course. Aren't they always?
