fuel/tank issues
anyone else have this issue?
on a similar note, i occasionally smell gas around the car (not at a gas station) and my mileage isn't what i'm expecting... i get around 16-17 mpg in mixed 60/40 city/hwy driving... shouldn't the ls get better than that?
could there be a gas leak or a gas tank issue?
There was, at one time, a TSB regarding that issue. I have a 2004, and it happens to me. The TSB replaces a part in the filler neck of the tank to correct the problem. As I recall, though, it will only be performed within the cars warranty period ..... I missed out on that.
Walt
FUEL TANK DIFFICULT TO FILL
TECHNICAL SERVICE BULLETIN
Reference Number(s): EG012-06, Date of Issue: May 25, 2006
LEXUS: 2001-2005 LS 430
GROUP:ENGINE
Related Ref Number(s): EG012-06
ARTICLE BEGINNING
INTRODUCTION
Some customers may experience difficulty when attempting to fill the fuel tank. The
fuel filler nozzle may click off before the fuel tank is completely full. Improvements
have been made to the fuel filler inlet pipe to correct this condition.
APPLICABLE VEHICLES
z 2001 - 2005 model year LS 430 vehicles produced BEFORE the Production
Change Effective VIN shown below.
PRODUCTION CHANGE INFORMATION
MODEL PRODUCTION CHANGE EFFECTIVE VIN
LS 430 JTHBN36F#65037924
PARTS INFORMATION
PARTS INFORMATION
MODEL
YEAR
PREVIOUS
PART NUMBER
CURRENT PART
NUMBER
PART NAME QTY
2001 - 2005 77201-50080 Same Fuel Tank Inlet
Pipe Sub-
assembly
WARRANTY INFORMATION
OP CODE DESCRIPTION TIME OFP T1 T2
EG5050 R & R Fuel Tank Inlet Pipe 2.0 77201-50080 9A 99
FUEL TANK DIFFICULT TO FILL -2004 Lexus LS 430 Page 2 of 2
Sub-assembly 77201-50130
APPLICABLE WARRANTY
This repair is covered under the Lexus Emissions Warranty. This warranty is in
effect for 48 months or 50,000 miles, whichever occurs first, from the vehicle's in-
service date. Warranty application is limited to correction of a problem based upon a
customer's specific complaint.
REPAIR PROCEDURE
1. Add fuel to vehicle to confirm that the fuel tank is difficult to fill.
2. Remove the fuel tank cap from the fuel filler inlet pipe.
3. Remove the fuel filler shield by removing the four (4) Phillips head screws and
one (1)14 mm nut.
Fig. 1: Removing Fuel Filler Shield
4. Remove the left rear wheel.
5. Remove the left rear wheel house liner by removing the nine (9) 10 mm nuts, two
(2) hex head screws, one (1) 10 mm Phillips head screw, and one (1) plastic clip.
6. Disconnect the fuel tank inlet pipe sub-assembly from the fuel inlet hose and the
fuel tank breather tubes.
7. Remove the fuel tank inlet pipe sub-assembly by removing the bracket with two
(2) 12 mm hex head bolts and then the clamp with two (2) 10 mm hex head bolts.
Fig. 2: Removing Fuel Tank Inlet Pipe Sub-Assembly
8. Install the NEW fuel tank inlet pipe sub-assembly.
9. Add fuel to the vehicle to confirm that the difficult-to-fill condition is eliminated.
10. Reassemble in the reverse order of disassembly.
Frankly, I think Lexus does itself a real disservice to the brand by not fixing ALL cars with the problem since it is clearly a manufacturing problem.
When I spoke to the dealer they said the above TSB procdure was $600.
This is my only negative feeling about Lexus.
My point is that Lexus should man-up and do the right thing. This is clearly a manufacturing problem and maybe even a serious enough issue to warrant a recall.
To have the guts to tell a customer who bought because of the brand that there was a "gotcha" moment out there whne you went to fill up your gas tank fo rthe first time.
But we will ONLY charge you $600 to fix our engineering problem.
Who is going to test for something that no other car has a problem with.
Again, IMO Lexus should take care of this problem not stick unsuspecting buyers of pre-owned vehicles with this annoying manufacturers mistake.
