Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
Has anyone ran 275/35-18 tires in the rear with stock wheels?
Old Oct 29, 2009 | 10:01 AM
nomobmw's Avatar
nomobmw
Default Has anyone ran 275/35-18 tires in the rear with stock wheels?
I am considering dumping my crappy stock Bridgestones for some Michelin Pilot Sport 2s and saw that I could run wider tires in the rear on the stock rims. I'm not really interested in new rims as I don't want to go much lower profile for ride quality's sake but I am interested in getting more torque on the ground.
Of course, the drawbacks are not being able to rotate, but has any one run a setup like this on their 450h and did you have better grip from a standstill? Currently if I slam the throttle from a stop the traction control generally steps in and I'd prefer not to turn it off and burn out. .
Old Oct 29, 2009 | 12:14 PM
rominl's Avatar
rominl
exclusive matchup
stock wheels are 8" wide right? imho 275 would be way too wide
Old Oct 30, 2009 | 08:06 AM
nomobmw's Avatar
nomobmw
Well, I'm basing it on TireRack stating that as an alternate fitment. I'm sure that it will have a little hang over the rim, but since I've got roll-control I have no choice but to go with the stiff side-walled runflats.
Old Nov 3, 2009 | 05:09 PM
man0fsteel's Avatar
man0fsteel
Default roll control req's runflats?
Nomobmw - when you say roll-control, are you referring to the traction control? I've got this and wanted to move away from the runflats but your post suggests the car is designed to utilize the stiffer walled tires. Where can I read more about this?
Thanks
Old Nov 4, 2009 | 08:57 AM
nomobmw's Avatar
nomobmw
man0fsteel:
Actually, the problem is much more "overt" than that. . roll-control is called Active Stabilizer Suspension System in Lexus-speak and it basically has electric motors attached to the stabilizer bars that torque them in such a way as to counteract body roll when you are cornering. The net effect is it makes the car's handling MUCH better and eliminates the need to counteract body sway when turning. It also is a better compromise than having extraordinarily strong anti-sway bars as it allows for a smoother, more comfortable ride when high performance handling is not required.
If you have this system, however, the electronics package and supplemental battery take up the space in your trunk where your spare tire would normally go which leaves you with no choice but to use runflats.
Here is the Wiki: http://en.wikipedia.org/wiki/Active_...pension_System
and here is the Lexus video on the system:
http://www.lexus.com/lexus-share/dem...s/asss_nav.htm
Old Nov 4, 2009 | 02:09 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Agreed. For a 275 tire, I would suggest at least a 9.5" - 10" wide wheel. A 275 on a factory wheel would hang over quite a bit and look odd, IMO.
bbong
IS F (2008-2014)
Jan 5, 2015 08:51 AM
akfd
GX - 2nd Gen (2010-2023)
13
Jan 10, 2011 03:57 PM
UCrazyKid
IS F (2008-2014)
13
Aug 29, 2009 07:42 PM
lx470man
IS F (2008-2014)
32
Jun 11, 2009 10:34 PM
2slow
Mar 12, 2009 10:33 AM
