This is a simple one, at the top left of the shift plate just above the "P" for park there is a little slot, take a small screw driver and insert it into the slot and it will release your park lock and you will be able to shift to neutral! Good luck!
Forgot to ask...will I still have steering and foot break control? As soon as it will come out of the garage, it's downhill into the street
You'll have to have the key in the ignition and turned to the "on" position to free up the steering column lock. You will have neither power steering or power brakes, so you have to muscle it more than if the engine was running, but both will function.
