Getting into Neutral w/ dead battery
Old Oct 9, 2009 | 06:53 PM
Peter_Klim's Avatar
Peter_Klim
Default Getting into Neutral w/ dead battery
So my car battery is dead and my car is faced-in in my little apartment garage. I can't pop open the hood because there is a shelf above it.
I was told I can put the car in neutral and then push it out. How do I get it into neutral?
Old Oct 9, 2009 | 08:13 PM
mdpuff's Avatar
mdpuff
This is a simple one, at the top left of the shift plate just above the "P" for park there is a little slot, take a small screw driver and insert it into the slot and it will release your park lock and you will be able to shift to neutral! Good luck!
Old Oct 10, 2009 | 02:41 AM
tromly's Avatar
tromly
+1, great answer mdpuff
Old Oct 11, 2009 | 10:02 AM
mpx's Avatar
mpx
I have a similar problem, only its opening the trunk with a dead battery?
Old Oct 11, 2009 | 10:04 AM
Yes's Avatar
Yes
lift up the bottom panel of the center console and you'll find the trunk release.
Old Oct 11, 2009 | 10:47 AM
mpx's Avatar
mpx
thank you very much ....
Old Oct 12, 2009 | 08:45 AM
Peter_Klim's Avatar
Peter_Klim
Thanks guys! I will try it tomorrow! (I'm 3K miles away from home right now!)
Old Oct 13, 2009 | 01:41 AM
Peter_Klim's Avatar
Peter_Klim
Forgot to ask...will I still have steering and foot break control? As soon as it will come out of the garage, it's downhill into the street
Old Oct 13, 2009 | 08:52 AM
PHXSC's Avatar
PHXSC
You'll have to have the key in the ignition and turned to the "on" position to free up the steering column lock. You will have neither power steering or power brakes, so you have to muscle it more than if the engine was running, but both will function.
Old Oct 13, 2009 | 05:50 PM
Poqman's Avatar
Poqman
PHXSC is dead on. You can also control the downhill by using the emergency brake.
keldon595
May 11, 2018 11:47 AM
Lexi66
Feb 25, 2018 09:42 AM
new_berlin
HS 250h Model (2010-2012)
Dec 18, 2017 10:13 AM
katkatgre
Maintenance
Sep 3, 2017 01:17 PM
lexuspower
Sep 19, 2013 12:54 PM
