Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
BC Racing SEMA Sale ~ $100 OFF - IS & GS AWD !
Old Oct 8, 2009 | 09:02 AM
CircuitMS's Avatar
CircuitMS
Default BC Racing SEMA Sale ~ $100 OFF - IS & GS AWD !
That's Right, We are having a HUGE SEMA SALE. We have been allowed to sell the AWD versions of the BCR coilovers at reduced prices for the next 4 weeks! Then it's back to the normal pricing! We have these IN STOCK and ready to ship, Hurry and get yours!
Circuit Motorsports is proud to provide the Lexus club with BC Racing Coilovers!
We are the only shop to carry the exclusive AWD IS and GS versions of these awesome coilovers. Not to mention that BC Racing is the only manufacturer to produce a coilover for this application. We heard your cries for help and we responded, here they are!
ALSO - Be sure to PM us and aks about our SALE PRICES on all of our RWD Lexus kits too!
BC Racing BR series coilovers are perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and the patented concave lower locking ring keeps it locked in. They are dual-height adjustable, which means you don't sacrifice shock travel when you lower the car, since spring preload is completely separate from ride height. We can provide them with the OTS spring rates, or you can choose a softer or stiffer setup, it's up to you. We make it extremely easy for you to customize your suspension for your car.
We also provide the option of pillowball mounts front and rear, or rubber mounts front and rear, your choice. Rubber mounts provide an extra barrier between your suspension and chassis, reducing NVH. Pillowball mounts will be a little noiser, but they provide better feedback through your chassis and a stiffer mount for those of you looking to track your cars.
Here are the specs:
General
-Designed specifically for the IS & GS AWD systems
-Mono-tube shock design
-30 levels of damping force adjustment
-Separate Full length height adjustable
-Pillowball front mounts
-One year warranty
-Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
-Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
-Patented concave lower locking ring, to prevent unseating
-Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
-T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
-Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
-High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
-2 step coating process utilizing nickel and chromium plating to prevent corrosion
-Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
-An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
-Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
This SEMA SALE is only good for thenext 4 weeks,then it's gone, so don't delay!
We also can privide suggestions on street and track setups, suspension advice and plans and general setup specs, we know our suspensions!
We also carry BC Racing coilovers for these Lexus applications:
-08+ ISF
-'98-'05 IS-300
-'06+ IS-250 and IS350 & AWD
-'92-'97 GS300/350/400
-'98-'05 GS300/350/400
-06+ GS Series & AWD
-'92-'00 SC300 and SC400
-'95+ LS400/430
-'00-'07 LS430
WE GIVE THE BEST DEALS AND PACKAGE PRICES ON BCR COILOVERS!
Feel free to PM or email with any questions or orders!
Want to adjust your damping on the rear coilovers without tearing apart your trunk? Get Extenders! These little cables attach to the adjuster **** and can be punched through the trunk liner to give you damping access for super easy adjustment!
Old Oct 8, 2009 | 11:17 AM
br3akenout's Avatar
br3akenout
i think i asked for a quote in the past but i can't seem to find it in my inbox so unfortunately i have to ask again please PM me a quote for the coilovers for an IS250awd shipped to 07304. Thanks!!
Old Oct 9, 2009 | 09:06 AM
CircuitMS's Avatar
CircuitMS
No problem, PM sent
Old Oct 10, 2009 | 11:32 AM
CircuitMS's Avatar
CircuitMS
Saturday Sale Bump!
Old Oct 10, 2009 | 08:08 PM
chwang1973's Avatar
chwang1973
for IS350 to Orlando
Old Oct 12, 2009 | 08:43 AM
CircuitMS's Avatar
CircuitMS
PM sent
Old Oct 13, 2009 | 01:49 PM
CircuitMS's Avatar
CircuitMS
Tuesday bump, all PM's replied!
Old Oct 14, 2009 | 09:07 AM
CircuitMS's Avatar
CircuitMS
Wednesday Pm's sent and replied
Old Oct 14, 2009 | 11:00 AM
LEXUSF's Avatar
LEXUSF
On your website it shows 1099.00 for a while now. What is the special price for sema??
Old Oct 15, 2009 | 09:44 AM
CircuitMS's Avatar
CircuitMS
PM's sent and replied
Old Oct 16, 2009 | 09:39 AM
CircuitMS's Avatar
CircuitMS
It's Friday! All PM's replied!
Old Oct 17, 2009 | 09:10 AM
CircuitMS's Avatar
CircuitMS
Saturday Sale bump!
Old Oct 19, 2009 | 10:24 AM
CircuitMS's Avatar
CircuitMS
All weekend PM's replied!
Old Oct 20, 2009 | 02:42 AM
Confusion's Avatar
Confusion
93 sc300 zip code 96792
Old Oct 20, 2009 | 06:46 AM
nisenku's Avatar
nisenku
09 is250 awd 20136. thanks
