removing air filter box for cone fiter 2000 es300
i am new to the group,everyone calls me saga. i recently got a 2000 es300 with 68k on her. my mom works @ a lexus dealer & took this car in on trade. i have all the service records. the previous & only owner brought the car in for every scheduled maintenance. the car was garage kept & everything including the paint is near mint.
so i would like to do some performance mods. i figured i would start by taking out the air filter box & add a injen cone. when looking @ filter box it seems to have a sensor attached to it. so if i removed the box what do i do with the sensor. i think it is a mass air sensor,not sure though. any help would be great. any other suggestions in getting some more hrsp. out of her would be greatly appreciated.
thank you, saga
Welcome to VVTI equipped motors.
See pics below just took them, the MAF is PART of the airbox...
I wanted an intake to get it to sound nicer at higher RPM's and to pretty much have a reusable filter... But have been using the regular ones for now.
just a little more throaty sound would be cool,even if the car can't get out of it's way getting onto the highway.
anyone have any ideas besides getting a different car, to add some hrsp.?
I have that intake for sale, the MAF flow sensor is different on my car, its a lot smaller than the cut out on the intake, it was for a different year ES
Contrary to popular belief, they give no gains, get clogged up much faster, and a a ***** to maintain.
I was told that the dry filters are best, and at a few bucks/filter i am willing to pay, vs. 80$ USD for an overglorified K&N, and on top of that another 20$ for the cleaner.
I am going to 'mod the box' with an intake going into the box for more air to rush in.
To each his own but just for the record the K&N I purchased cost me $32 on sale 4 years ago.
I think now they are around $40 not $80.
The "Dry Filters" I think you must be referring to are the "AFE Pro Dry Filters" which cost the same as a K&N around $40 or so not a "few dollars", they are a good filter also but not really any better than a K&N.
I used to use 2 K&Ns on my old Baja Bug back in the 80s.
The Bug was basically just a sand rail with a few pieces of VW body & pan on it and the engine was completely exposed.
I would go to the desert and sand dunes, go into deep mud holes you name it, the K&N would be almost unrecognizable it would be so covered but when I would take them off the throat of the carbs were clean as a whistle and the K&N even caked with dirt was breathing nicely.
Getting dirty faster means they trap dust better.
They give just much of a gain as any other quality air filter and I just cleaned & re-oiled mine last week, took me all of 10 minutes tops. No problem to maintain at all.
You can buy the K&N filter charger kits for under $10 several places online and also at Pep Boys for under $10 which will last you about 7-10 years.
I bought mine at Pep boys for $8.99 4 years ago and still have 1/2 of it left.
You don't have to clean a K&N until it gets real dirty.
So get what ever floats your boat but no need to spread false BS about K&N in the process.
Iam sure the Dry Filters will work just fine.
I am simply restating what i personally expereinced [had one on a 2003 JEtta] and it was garbage.
They may be cheap for you since you are in the US, the above {USD** was a mistake, i meant to put on CAD. Even on eBay for ME it is about 80$ USD when it is all said and done at my door. Same with the cleaning kit it is ~22$ at my local parts store.
I had the filter on the dub, and it was junk. I put it in and it got dirty fast. I went to clean it/etc, the cleaner doesn't even work, the oil did not even bead as it was supposed, it ALL ended up at the bottom of the airbox.
Again i am basing my personal point off a panel filter, perhaps the cones are better to clean, etc.
Furthermore i have talked with many automotive pros, that know their stuff and they tend to say the same, that it is useless in an OEM application and holds no benefit over a K&N, thus it is better to use a OEM filter or one of the dry ones.
Sorry man, because it worked for you, great, i am really happy for you.
What is it to you anyways? Why do you value my criticsm so much? Are you are rep for K&N ? LOL
