FIGS MEGA Arm interest thread. All parts in, how many should I make?
Again these will resolve Toe and camber issues with a drop to 2.25" and mitigate some of the other extreme drops I am seeing in this forum. I am also designing a toe link that should be able to be undermounted and that should eliminate the rest of the toe scrub tire wear issues for the rear.
a few pics, also look at the other thread in this forum for install pics and review.
Let me know, thanks, Fig
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
I see alot of you posting up your alignment specs, while this is important for stock geometry suspensions and ride heights, you have to remember the suspension acts differently when lowered. With less travel and the arc of the connecting components made more steep, things will pull in different ways. So you have to think of how the suspension travels, not how it sits statically if that makes sense.
Fig
i would also recommend a tie-rod adjusted for bumpsteer. i'm getting raped by these things and it's pretty dangerous if i don't pay attention to the road. i'm pretty sure half of the forum has this same issue but never talks about it.
cliff: roll center adjustment for front and rear, bumpsteer adjustment.
I'm still confused on how your arms are better / different in application compared to rear RCA's. Your arms don't lower the car like a RCA would from what I gather and I was under the impression that lowering the car with the RCA was a good thing.
So ... your knowledge and information on this is appreciated along with if your arms help increase ride quality or are they just to correct camber. Let us know. Thanks,
Scott
probably a lot more complicated than that....P
Scott
Its also not a good thing to add weight to the suspension. This is unspring weight, weight that impacts how the damping in the suspension works, weight that is accelerated when you hit a bump. It will make things…harder to control and put more demands on your damping, especially on rough road surfaces.
Also, I think it is important to retain the stock alignment adjustment on the outside. So my arms allow a length offset to be set on the inner mount and also allow alignment adjustment by the OEM mechanism, the cam bolt. Other solutions require that you chose a setting and leave it there. Adjustment of the alignment requires the changing out of spacers and inserts to come up with a workable solution. This means time and expense at the alignment shop. It may also take a special shop to get a mechanic that understands what is going on…maybe even multiple visits and hassles.
My solution is a simple resolution to the problem that replaces the whole control arm with one that has the correct adjustment and mounting points. Consequently I added improvements to the OEM design by replacing the inner mount with a spherical bearing, adding multiple mounting locations for the sway link and making it very close to stock weight so the damping control is kept unchanged.
The correct way to lower a vehicle is with an adjustable coilover shock or in the most cost effective case, a shorter, stiffer spring. The GS, like the IS, is a complicated sum of link angles and constraints on each. It was important to add the spherical bearing to allow misalignment in the mount and still keep the suspension from binding and also keeping all links within the intended influence of their design. Also by making the link shorter in its original arc path, it allows the rear control arm to fight the toe link under compression…less bump steer, more control once again.
The biggest misconception I see on forums regarding suspension is that if the suspension can be "aligned" to factory specs, all problems are fixed. In reality, alignments are a single sample of the suspension along its travel curve and may or may not mean you have a problem at the extremes of travel or at another point. If the suspension stayed in one place, it would not be effective in its job...which is to maintain traction and control over multiple surfaces. Stock specs apply to stock suspension at stock ride height and if done properly, you will need to make adjustments to a lowered suspension to get things aligned, but they may not be the specs that they have loaded into the computer.
There are too many suspension combinations for me to suggest alignment settings at each intersection point, but my arms do allow easy adjustment of the rear suspension in the manner it was intended by design. They also provide a few extra features that make it a complete integration into the system. I have been meaning to make an animation of the stock suspension to illustrate how changes affect the travel path or dynamic alignment, but I simply have not had time to do it quite yet. I am happy to offer my solution to GS members but I also realize you guys have different needs that the IS crowd. So please give me feedback on what things concern you when lowering you vehicle. The development of these arms was driven by two goals.
1. Elimination of inner tire wear on the rear, especially with low profile tires and high positive offsets.
2. Increased control in the rear through mitigation of bump steer and reduction of energy storage in the rear control arm due to the rubber bushing. When the arm twists, the bushing makes it twist back, torsional storage of energy..this impacts the location of the suspension.
I believe both of these things were accomplished while also keeping the costs significantly lower than similar products offered in other markets that do similar things.
I look forward to your feedback and your continued questions. Someday I will have an illustration for all of this.
Thanks,
Mike
Thank you for your explanation of how it all works.
One more question: With your arms is there a degridation in ride quality, same ride quality as stock arms, or an improvement in ride quality?
Again, I appreciate your information. Thanks,
Scott
