Luminics vs. Nokya
Old Sep 17, 2009 | 12:14 AM
josephx66's Avatar
josephx66
Default Luminics vs. Nokya
Whats the difference between the 2500k 55w bulb and the 2500k 70w bulb? is there light output difference the nokya is the 70w and the luminics is the 55w.
Old Sep 17, 2009 | 01:43 AM
pandy_88's Avatar
pandy_88
dont get luminics! THEY BLEW OUT MY DRLS! now i have no dlrs for 1 year
Old Sep 17, 2009 | 02:25 AM
llamaboiz's Avatar
llamaboiz
umm... i have no idea what this means...
Old Sep 17, 2009 | 04:43 AM
Edz71's Avatar
Edz71
Hi guys,......
Our cars as most run on 12 volt supply so any increase in wattage "electrical power" will lead to more curent "amps". The more amps produced equals more heat and the problem isn't the wire but any point where there is a joint or termination at the end of a wire like the point between the bulb prongs and bulb receiver.
Here is the calculation for OHMS law ..............
voltage (E) = current (I) X resistance (R)
power (W) = voltage (E) X current (I)
.... 55 watt bulb
(P)= 55 watts (divided by) (E)= 12 volts ... equals = 4.58 amps (I)
.... 70 watt bulb
(P)= 70 watts (divided by) (E)= 12 volts ... equals = 5.83 amps (I)
I know it isn't a huge increase in current but it's enough to case a problem on some cars. My neighbour changed his DRL's on his BMW and after 3 months the connector to the bulb burnt out causing a short and taking out the harness and lighting control modual............ this is by far the most extreem I have ever heard of.
Sorry for the long post I got carried away, hope it helps.
Edz
Old Sep 17, 2009 | 07:34 AM
dangy's Avatar
dangy
I had Nokya for my fogs. They were good until they blew. I heard Luminics were better.
Old Sep 17, 2009 | 07:35 AM
josephx66's Avatar
josephx66
So should get the Luminics then?
Old Sep 17, 2009 | 07:50 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
for about the same price, why not a HID kit?
Old Sep 17, 2009 | 11:39 AM
moo_juice's Avatar
moo_juice
same price?
the bulbs are like $20, the absolute cheapest hid kit on here is like $70, most are at least $100.
Bulbs are also a simple 5 min install. The hid conversion for fogs is going to require bumper removal. Not saying the work isnt worth the final product.
oh and ive had luminics on my car for over a year now and they are still going strong.
Old Sep 17, 2009 | 12:47 PM
silentbob's Avatar
silentbob
have 2500k luminics in my drls/highs for 3 months now, like em alot. i feel like i've read here about nokyas going out more often than luminics, but that could just be b/c more people here go with nokyas...
Old Sep 17, 2009 | 02:35 PM
panda327's Avatar
panda327
i have those luminics ... they are running strong . had them for a month
Old Sep 17, 2009 | 02:38 PM
ton3r's Avatar
ton3r
i have the luminics 2500k. i've used them for way over a year and still going good
Old Sep 17, 2009 | 02:39 PM
GiantsFan's Avatar
GiantsFan
Luminics FTW! Plus... draws less power, so there is less of a chance the harness will melt
Old Sep 17, 2009 | 03:23 PM
Namster's Avatar
Namster
I have luminics 2500K and it still runs good for at least 1.5yrs now. I'm still waiting for it to die out so I can upgrade to HID but it just won't...oh well
Old Sep 23, 2009 | 08:47 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
You definitely don't want to go with anything over your stock wattage.
Our putco bulbs (backed by a lifetime warranty from Putco) will blow both out of the water =)
http://www.KBcarstuff.com/Halogen_Au...ulbs_s/271.htm
Steve
Old Oct 19, 2009 | 05:52 PM
kdii02's Avatar
kdii02
Installed my Luminics 2500k JDM Yellow fogs tonite. They look great, install took 20 mins tops. Thanks for the info guys!!
