Smartkey Upgrades?
Old Sep 13, 2009 | 02:20 AM
KILLERGS4's Avatar
KILLERGS4
Originally Posted by Jim_Chow
I don't ever remember seeing a metal key as part of the new push button fobs.
even the new key fobs has metal key, to open the door just in-case the battery dies (also to lock glove compartment and trunk)... doesn't the key warn you if the battery is low?
Old Sep 13, 2009 | 05:28 AM
SerasLibre's Avatar
SerasLibre
Yes, it warns you by not working. I had the same issue with my Avalon once and had to hold the key up to the pushbutton to start the car.
Old Sep 13, 2009 | 11:29 AM
Griff48's Avatar
Griff48
I seem to remember when reading my owner's manual that the multi-function panel warns you if the key battery is weak. That should happen well before it will no longer unlock the car.
Gene
Old Sep 14, 2009 | 04:11 AM
AlexusAnja's Avatar
AlexusAnja
If you wanted to, you can surely swap out the whole old SmartAccess with the new system and jimmy together a pushbutton somewhere on the car. I'm not sure how cost effective that would be because I'd gather labor and parts probably in excess of $4K. That's a lot of dough to correct a "large key" problem.
Old Sep 14, 2009 | 05:24 AM
Tee's Avatar
Tee
Now that would be a kick *** mod, converting our current smart key over to the new push button start one. I also think it would be a lot of work and $$$$ to do it, another mod would be to swap Gen 4 screen with a Gen 5 sreen for the higher rez screen.
Old Sep 14, 2009 | 11:35 AM
gs4bkny's Avatar
gs4bkny
Default push button
that would indeed would be a kick *** mod. question: other than obviously the ignition switch, what other components on the car would have to be changed/altered in order for this mod to be successfull?
Old Sep 14, 2009 | 06:21 PM
LS430inDE.'s Avatar
LS430inDE.
I thought of the tilt/telescoping steering wheel right off the bat. When would it "assume the position?" As you're pushing in the button? After you release the button? After successful startup?...
blanks81
GS F (2016-present)
59
Sep 25, 2024 12:23 AM
maaloxx
Dec 27, 2011 08:45 PM
TEXAS83
Oct 19, 2009 11:08 AM
beevo
GX - 1st Gen (2003-2009)
Sep 29, 2009 01:19 PM
vpopx2
GS - 1st Gen (1993-1997)
Jul 2, 2004 12:27 PM
