Navigation DVD Update
The latest dvd will cost about $200 to $250. I think i recently saw it for $200 but I don't recall if that included a $50 rebate for turning in the prior year's dvd or not. Installing it is easy and you shouldn't pay for that. It's as simple as ejecting the old dvd from the player and feeding in the new one. DVD player is under the tool tray underneath the carpet of the cargo area.
Then once the disc is installed they put the car back togther. Then they have to input all of the work into the computer for billing.
1) Remove rear tool tray( NAV DVD player is underneath)
a)fold down rear seats
b)find velcro tabs on each side of rear tray cover where it meets back seats
c)lift velcro tabs
d)slide fingers gently along edge where rear cover meets rear seats to release 5 plastic push pins.
e)Use 12mm socket to remove the 2 now visible hinge bolts
f)remove tool tray cover
g) remove tool tray, There are 2 black push pin on both sides that pry up easily. NAV DVD player should now be visible on passenger side
2) Put ignition in ACC position
3) If there is a dust cover on unit remove it. Mine did not have this. Some do.
4) There should be a "slide type button" on your left of the unit. Slide this button to your left(facing unit). DVD should eject
5) Insert new DVD
6) Slide button back to original position
7) allow NAV to update before turning off ignition( check NAV Screen)
8) Reassemble in reverse order.
Hope this helps. I just replaced mine in a 2008 RX. It may sound like a lot , but I was finished in 15 minutes.
Tip: If you are uncomfortable with DIYs, take your time and think it through.
Use a light and see if you have missed this step.
If you can put a CD into the slot in the dash, you can put a DVD into the slot in the trunk. Just keep the engine running until the disc is fully read for the first time, as sometimes new elements are loaded into the operating system.
If a car is in the shop for something else, the shop should do this for free, as the incremental time involved is negligible.
