Proper Break-In Procedures
Old Sep 2, 2009 | 07:36 PM
hanjkwon's Avatar
hanjkwon
Default Proper Break-In Procedures
I'm driving any faster than 60mph. No hard breaking. No hard accelerating. Turning off A/C before turning off the engine (not sure if this is necessary though). Not revving it higher than 3000rpm. Also driving duration is about 1 hour. Is there anything else?
Old Sep 2, 2009 | 07:39 PM
hanjkwon's Avatar
hanjkwon
Planning to do this for 1000 miles.
Old Sep 2, 2009 | 08:03 PM
Kyousuke's Avatar
Kyousuke
I've heard that you shouldn't keep the engine at a constant speed while cruising--you should vary the engine speed. Not sure if it's true though...
Old Sep 2, 2009 | 08:04 PM
rxets's Avatar
rxets
Don't keep in the same speed/rpm for a long period of time. This is the good one.
Just follow the owner manual, you will be fine.
Many ppl never follow such break-in rules, they're often fine, too.
You should relax.
Old Sep 2, 2009 | 08:41 PM
Kyousuke's Avatar
Kyousuke
Is there a set RPM which you cannot go over? Some say 3000, some say 5000. Which one is it?
Old Sep 2, 2009 | 08:55 PM
hanjkwon's Avatar
hanjkwon
I guess it's not a good idea to go on the freeway.
Old Sep 2, 2009 | 10:22 PM
Hal56's Avatar
Hal56
i have been told to break in a car the way you will regularly drive it--except do not push what is a redline and also do not brake too hard early on.
I know we have been told change oil at 5000 miles--I like to change oil at 1000 miles the first time--it may be an old story thing but there used to be sand in the engine block from building the engine--and early oil change wil get that sand out-
also there are magnetic plugs for the oil drain plug--the benefit here is that if there are any slivers of metal in the engine the magnetized plug grabs it and keeps it from screwing up the engine.
Old Sep 3, 2009 | 04:23 AM
lex's Avatar
lex
Copied from the manual:
Breaking in your new Lexus
To extend the life of the vehicle, observing the following precautions is recommended:
l For the first 200 miles (300 km):
Avoid sudden stops.
l For the first 500 miles (800 km):
Do not tow a trailer.
l For the first 1000 miles (1600 km):
• Do not drive at extremely high speeds.
• Avoid sudden acceleration.
• Do not drive continuously in low gears.
• Do not drive at a constant speed for extended periods.
Old Sep 3, 2009 | 05:44 AM
sightdev's Avatar
sightdev
break-in period is no longer promoted by manufacturer and last time I have seen "break-in" reminder was in the early 80's. Drive normal during first tank to break-in the tires and brake and avoid towing. We took our 10RX on 3 hour trip [avg 80 mph] after first tank and this is typical driving for me in the past 20 yrs or so of purchasing new vehicles. I follow 7k oil change regiment using Mobile 1 and I have never had engine problem. Some of the Jeep I have had as much as 140k before replacing but none of the vehicles required additional oil between changes. Enjoy your vehicle and use it as it was intended, “utility” vehicle.
Old Sep 3, 2009 | 05:50 AM
The G Man's Avatar
The G Man
2/3 is a good rule, stay under 2/3 of the engine's max rpm and 2/3 of the max speed for about 700 to 1000 miles. No jack rabbit start and drag your brakes the 1st few hundred miles.
Old Sep 3, 2009 | 06:30 AM
Hal56's Avatar
Hal56
10 years ago I drove a practically brand new Vette cross country--I varied the speeds--sometime 75, sometimes 105 and once 135.
But never hit the brakes hard nor accellerated fast. :-)
BTW--RPMS at 135 were not close to red line.
But--comparing the two cars--the vette and RX450? Totally different -both great in their own ways.
Old Sep 3, 2009 | 09:36 AM
Mbenz528i's Avatar
Mbenz528i
I have been easy going on the new RX (driving in eco mode helps the hard accelaration) and was also (slightly) worried about break in. I am driving to Ohio tonight for labor day and we only have 200 miles on the odo, so this will be our first major trip. I basically am taking the manuals advice, but from what you guys are saying, should I avoid cruise control in during this trip?
Old Sep 3, 2009 | 10:50 AM
The G Man's Avatar
The G Man
Do not use cruise control and vary your speed.
Old Sep 3, 2009 | 12:06 PM
DOUS's Avatar
DOUS
https://www.clublexus.com/forums/rx-...in-period.html
JimInTN
May 18, 2019 09:08 AM
jdshaw
RX - 3rd Gen (2010-2015)
Jul 17, 2014 09:54 AM
LexPaul
Feb 28, 2009 06:14 PM
kuwaiti
Mar 10, 2007 09:33 AM
imdchamp
Jan 15, 2002 12:15 PM
