DIY on changing servo motors
Old Aug 13, 2009 | 08:29 PM
  #61
Adam2562's Avatar
Adam2562
ahh i think i need the drivers side for me personally
Old Aug 14, 2009 | 11:10 AM
  #62
sakataj's Avatar
sakataj
lol...im fixing to need one of them too
Old Aug 14, 2009 | 03:39 PM
  #63
kblack's Avatar
kblack
Default Servo
Thanks for the post I just found out today! that mines went out, what a dammm shame its always something, everyday all day it never ends.
Now back to the bank to draw some more money out of my pocket.
Great Job!
Old Aug 17, 2009 | 11:53 AM
  #64
sakataj's Avatar
sakataj
Great Job!
get me some $$$ too,here....give the teller this note for me....and this bag
Old Aug 25, 2009 | 08:14 PM
  #65
Kbueno's Avatar
Kbueno
Thank-you very much for the DIY, 1st I replaced the mode servo, but it turned out to be the cooling servo. The back screw to the cooling servo is a PITA! Shoulda replaced both at same time as you recommended. So it seems I have a very used mode servo w a broken corner (where screw goes thru). If anyone wants it they can have it...I'm sure it'll hang on w 3 screws. I have to get back in there and fix the glove box light one of these days.....
Old Aug 26, 2009 | 11:08 AM
  #66
sakataj's Avatar
sakataj
yeah i told you'll, for all the trouble they are, i would just go ahead and do them both right then. oh and your welcome. glad to have helped man
Old Sep 5, 2009 | 12:49 PM
  #67
pflinker's Avatar
pflinker
Default Does the Air Mix servo have multi-stop positions?
I was wondering it the air mix servo has multiple stops or just goes from a beginning to end in a two position movement. My is currently going full from beginning to end only at the highest temperature setting of 84-85. There is no movement from 65-83 degrees. Just wondering if this is normal of sign of a bad servo.
This is in a 1999 GS300.
Thanks
Old Sep 5, 2009 | 01:20 PM
  #68
5t341th's Avatar
5t341th
sorry, i skimed thru the thread only.
is this the motor that moves the vents so it goes to body/feet/body+feet?
if so, when it fails, did yours make noises? my mom's rx300 makes loud buzzing noises
Old Sep 7, 2009 | 10:09 PM
  #69
Kbueno's Avatar
Kbueno
Thanks
Well the arm has a long sweep...so it would seem it has variable positions?
Old Sep 7, 2009 | 10:11 PM
  #70
Kbueno's Avatar
Kbueno
Theres two that generally fail..the one you are talking about is the mode servo and yes, when they fail they make buzzing squeeking noises.
Old Sep 8, 2009 | 11:04 AM
  #71
sakataj's Avatar
sakataj
Thanks
yes this is a normal sign of a bad servo. arm has several positions
its funny the rx and gs seem to share this problem how come you dont hear about this problem in the other lexus models?
its variable
x2 but there are actually 3 that generally fail....the third is drivers servo funny the air recirculation servo NEVER seems to fail i wonder why
Old Sep 16, 2009 | 02:39 PM
  #72
EN_VY's Avatar
EN_VY
Didnt want to start a new thread, So I'll post here. I am getting a noise from behind my stereo. It sounds like if a cell phone was stuck somewhere and vibrating. It will do it randomly. Its deffinetly NOT coming out of the glovebox. I took out the ac vents and can feel some vibrating there. Could this be a faulty servo? Or is it something else?
Old Sep 16, 2009 | 02:44 PM
  #73
ElitistK's Avatar
ElitistK
it's a faulty servo motor. you can take the actual electric motor out and re-adjust the arm and then calibrate it again to see if it works, or replace the electric motor inside, or replacement the entire servo assembly.
don't try to force the arm into another position with the electric motor inside; you will snap the gears inside.
Old Sep 17, 2009 | 01:17 AM
  #74
RacingLuxury's Avatar
RacingLuxury
Default Thanks!
Thanks for the great write up man! This I hope will solve my cricket noise problems! And just FYI, some Toyota dealerships can get Lexus parts for a lot cheaper then what Lexus will charge... I will do this DIY asap.
Old Sep 17, 2009 | 05:59 AM
  #75
EN_VY's Avatar
EN_VY
I havent been using my ac?? So whats the deal?? Ill try and figure it out, its really annoying
