Anyone know what module this is...
Old Aug 20, 2009 | 08:48 PM
dRo15's Avatar
dRo15
Default Anyone know what module this is...
So I've had this noise coming from my dash for the past 2 days. I don't know if it has to do with my radio/nav but I snooped around a bit. It seems like the noise is coming from this module. Can anyone identify it and what does it controls?
Took the bottom of the dash panel off. Just showing so you have more of an idea of where this module is located.
Here it is hiding behind the vent outlined in red.
Old Aug 20, 2009 | 09:33 PM
GS300ToM's Avatar
GS300ToM
a blend door?? for the heater/ac
Old Aug 20, 2009 | 10:01 PM
GS4_Fiend's Avatar
GS4_Fiend
correct me if i'm wrong... servos making noise?
Old Aug 20, 2009 | 10:17 PM
dRo15's Avatar
dRo15
anyone know for sure what it is
Old Aug 20, 2009 | 11:14 PM
Debonair's Avatar
Debonair
I will look it up in the morning if no one chimes in with the answer by then.
Old Aug 20, 2009 | 11:50 PM
tnbigdawg's Avatar
tnbigdawg
It looks like one of the A/C servos. Check this thread:
https://www.clublexus.com/forums/gs-...ml#post4121280
Old Aug 21, 2009 | 03:46 AM
GS300ToM's Avatar
GS300ToM
yes im right haha... i call it a blend door but yeah servo
Old Aug 21, 2009 | 06:52 AM
dRo15's Avatar
dRo15
Thanks for the input fellas. That link looks like that's exactly what it is. Seems pretty pricey for that part but what else would you expect being a Lexus part. I haven't been using the car's heat or ac so I couldn't tell you if it was the wrong temp at all. Doesn't seem that hard to change but working under the dash upside down is a B.
Old Aug 21, 2009 | 01:54 PM
sakataj's Avatar
sakataj
yeah i do. its the drivers side servo motor. i been to lazy to do my drivers side since its summer right now but i already did my passenger side and will do this one soon. i promise this one will be SO much easier to do then the passenger side was.
i think i might attach this to my DIY someone showed you earlier so people know the placement of the drivers side one
thanks
Old Apr 21, 2010 | 12:33 PM
Rich23's Avatar
Rich23
Thanks guys... As I said in the other DIY, Im doing this, this weekend... Great help!
Old Dec 1, 2012 | 05:17 PM
xfea's Avatar
xfea
So I finally replaced the Driver's side servo - but BEWARE and save yourself hours of frustration. I took my old part to the dealer and got a replacement - exact same printed number on the part.
Looks JUST like the photos above.
But it is WRONG!
That part number now belongs to a different version (right handed verses left handed) so if you get the one pictured above it wont work.
Tried for hours to install it (it's a bear getting that top screw!) but couldn't get it. Finally looked online and found that there are Right and Left hand versions (the arm is 180 degrees different).
And the the old part number now goes for the new (wrong) hand version.
What you want is part number 87106-30351.
If you get the part that has the identical number of your old broken one it'll be wrong!
Old Jan 5, 2020 | 02:00 PM
8M6's Avatar
8M6
Replying to this thread to re-host the photos dRo15 originally posted. A lot of Firefox and Chrome desktop extensions for fixing Photobucket images are broken now and I don't think there's any recourse for mobile users. Hopefully this helps anyone seeing this thread from this point forward.
Old Jan 6, 2020 | 07:59 AM
captainva's Avatar
captainva
Glad that people are still updating old threads to make them more useful
Old Mar 5, 2020 | 03:33 PM
JohnBeng's Avatar
JohnBeng
Thanks for the clear photos! I just pulled out the driver-side actuator, opened it up as per related post, cleaned up the potentiometer and wiper finger contact surfaces, closed it back up, reinstalled (not much fun being tight and upside-down), but low and behold: the noise is gone, and it works perfectly! I once again have both hot and cold to the driver. The potentiometer surface looked like it was wearing out, so not sure how long it'll last. But at least I have time to find cheapest replacement. Thanks again!
Old Apr 2, 2020 | 04:16 PM
SaiyanGS3's Avatar
SaiyanGS3
I have a lot of free time due to the quarantine, so I attempted to tackle this again. Took me about two hours but I finally got the old part out. Finding the hidden screw was the worst part. I installed the new servo motor minus the hidden screw. I didn’t want to bother with opening and cleaning the motors. They’re fairly inexpensive now. No more gerbil sounds.
