Finally, A cheap fix for bad hood struts!
I finally received a generic repair kit for bad hood supports. This kit is attached to the existing bad strut. When you open the hood all the way, a spring-loaded rigid plastic arm swings into position and supports the bottom of the old strut. (see pic)
It took 15 minutes to install, and yes it is a perfect fit for 1st Gen GS. It has 3 different sized clamps and the largest one is the right size for our cars. The instructions tell you to disconnect the strut at the lower connection so you can slide the bracket over the end and onto the chrome shaft. The kit assumes your bottom connection is flat. It is not. Therefore save yourself the time and just place a little oil on the chrome shaft and force-snap the new plastic clamp on.Then you also get a little saw and mitre box to cut the rigid plastic brace to the correct length.
It works perfectly!!!! I bought it thru mail-order to J.C.Whitney in Indiana. It cost $8 plus shipping. It is called "Pylon Lift Lock" It is part number 8200. It claims you only need 1 kit even if both front struts are shot.
ONE WORD OF CAUTION. As the pic shows, I mounted this kit so the support brace faces the back of the car. If you mount it so it faces the front of the car, your hood will not close all the way
No More Ghetto brooms or wood stakes to hold up the hood!
One more pic
This is what the package looks like. (also.. no extra charge... a shot of the washing machine. )
You might be able to purchase this directly from the manufacturer.
The name of the company is "Pylon Manufacturing Corp" out of Deerfield Beach, Florida.
Happy New Year!
Happy New Year!
All you need to do is go to the side of the car, grab the hood and raise it slightly,then move the end of the plastic support away from the bad strut and gently lower the hood. There is no automatic hood release.... I am sure you all agree this small effort sure beats hauling out and then removing a wood stake.
You don't really want to know...... new hood supports are $67.00 each, expensive, but I'm sure the Lexus dealership will throw in a free smile as you leave with the new support ! Sorry to have such an attitude, but the Lexus dealership in Grand Rapids,Michigan leaves much to be desired in customer service.
Did anyone try this idea? I was going to try this in the trunk because apparently it lifts it on its own or something, I think all you need to do is find this part and drill a small hole. I might go and try this sometime.
https://www.clublexus.com/forums/sho...threadid=40752
Another question, though. What if someone forgets to move the arm and tries to close the hood? Would a bent hood result? I've seen that happen before on cars where the support is along the side instead of up front.
i don't think it would work for the trunk. even if it did, everytime you want to lower the trunk you would have to reach way back there and fold down the trunk lining because the struts are hidden.
Originally posted by Rico's Revenge
Hey John... I was talking about the shocks. Sorry for the confusion. I'm a little rusty with trying to get my points across.
