I use this product in my ES and 87 works like magic if you reset the ECU. It take a few tanks but it stops the timeing from retarding and increased performance, burns cleaner and increases my gas mileage. 12oz =$12 so, 1oz/ 12gals.
hey. does the es300 run on 87 or 91? i have an sc and i plan on getting an es300. i noticed that on my friend's es300 gas gauge it says unleaded. i need to save money on gas.
I'm curious if it is really necessary to run premium fuel in a 1997 Lexus ES300? The owners manual states 87 Octane is adequate, but I have heard different opinions from several sources stating that the car requires 91 Octane Fuel...Is this really necessary, or am I just wasting my money on expensive gas?
89 Octane is what I use. The difference between 87 and 89 or 91 and 89 is very minimal. Let's say the difference is 10 cents and let's assume you're getting 12-14 gallons per fill-up... you're spending only an additional 1.20-1.40 per fill-up.
Why not try running your ES for an entire month on premium.....document your findings & do the same on regular? Let us know.
I run my 05 ES 330 on regular.....Sunoco 87......I do not get any better or worse fuel economy than running Ultra 94......and my engine purrs like a kitten.
the car doesnt require 91 but you wont be wasting your money on it. higher octane numbers burn slower = better
Someone on a local forum [to me] did just this. Anyways findings show:
Both fuels = same thing. The difference is negligible. Although the driving style has a lot to do with. This test was done using typical/repeating driving habits.
I run it on 87. And if it happens to be cheap i'll pour in some 91/94 a few gallons or so. I never actually ran it on a full tank of premium.
I would think that the Lexus owners manual would be the definitive source, and since they say that regular is ok then disregard the other sources. I have a 1997 ES300 that I have owned since new. I have run it on both, and found no measureable difference using premium, so I now use only regular.
You will be wasting your money unless there is a noticeable increase in either power or fuel economy, and there won't be.
