Old headlights/projectors vs New headlights comparison PICS
Old Jul 24, 2009 | 11:27 PM
1jztts's Avatar
1jztts
Default Old headlights/projectors vs New headlights comparison PICS
Just finished my retrofit and I found out one of my headlight has been replace with a newer one with the update projector.
Heres a few pics comparing the old and the new for those who are interested.
I just shined a led flashlight through the back of the projector.
old
back
****ty pic, sorry. Hard to hold everything with both hands.
You can see the narrow and uneven pattern, not a good idea to stick plug and play hids kits in these. I had them my old soarer and the glare was pretty bad.
new
Nice wide even pattern with a sharper cutoff in the new one. Should be ideal for a quality plug and play kit.
Only problem I see is the square light at the upper left hand corner. You can probably block it off.
Old Jul 24, 2009 | 11:32 PM
felixsc300's Avatar
felixsc300
Invaluable info, thanks for the write up. I'll keep this in mind when I grab a set of HIDs for my SC.
What's up with the small block? Is that where the turning signal is supposed to be?
Old Jul 27, 2009 | 08:33 PM
1jztts's Avatar
1jztts
the small block is for lighting up street signs I think
Old Jul 27, 2009 | 09:30 PM
guod's Avatar
guod
do you have the part number of the NEW headlight? not just the projector.
Old Jul 27, 2009 | 11:36 PM
Luxor's Avatar
Luxor
Those squares inside the projector cause this glare above the cutoff line. My headlights are factory from 1998.
Attached Thumbnails Old headlights/projectors vs New headlights comparison PICS-hid2.jpg
Old Jul 27, 2009 | 11:50 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Nice.
Dig it.
Old Jul 28, 2009 | 06:54 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Good idea, great writup... too bad I just took both of mine apart and redid them completely.. I used O.L.T. method, and I love them again. I will have to keep this one in mind, if theres a next time!
Old Jul 28, 2009 | 12:12 PM
JKBHEAT's Avatar
JKBHEAT
The new style projectors are definitely better for use with a pnp kit. All you have to do is cover up the small hole (w/ tape, thin piece pf flash aluminum, anything else that you can think of), and your good to go.
Old Jul 28, 2009 | 12:31 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Is it possible to open it up completely and insert a custom cutoff piece?
Old Jul 28, 2009 | 04:14 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
edit: nevermind, seeing things. Honestly I like the old ones.
I adjust both lights so that they overlap a little, so you dont notice that the middle part is lower.
its pretty close to a flat line on the old ones.
Also seems like they shoot more light on the corners on the ground which I like more.
Old Jul 28, 2009 | 05:38 PM
Black Fire's Avatar
Black Fire
in the 3rd pic 1jztts posted, ( all that uneven crap thats sits in front of the bulb) i went and cut out all of it, its been about a month now and no probs with the po pos, does anyone know if doing thats illegal?
Old Jul 29, 2009 | 06:40 AM
Jeembo's Avatar
Jeembo
Whoa.. I have a '99 and mine look NOTHING like that. No glaring at all above the cutoff line except for the cool "rays" from the city lights. I'll have to get a pic.
Old Nov 8, 2009 | 06:55 PM
Luxor's Avatar
Luxor
So I went ahead and took care of the problem, all I did was simply stuff some aluminum foil in that hole to completely block off the squares.
Attached Thumbnails Old headlights/projectors vs New headlights comparison PICS-headlight-install-2.jpg
Old Nov 8, 2009 | 06:56 PM
Luxor's Avatar
Luxor
Here is a picture of the the hole blocked off.
Attached Thumbnails Old headlights/projectors vs New headlights comparison PICS-headlight-install-001.jpg
Old Nov 8, 2009 | 07:07 PM
Mr.NA_T's Avatar
Mr.NA_T
Nice, I would of left the square hole. IMO.
