J.Clarkson gives 2010 MB E550 1/5 Stars
Old Jul 21, 2009 | 07:21 PM
GFerg's Avatar
GFerg
Speaks French in Russian
CL Folding 25,000
Default J.Clarkson gives 2010 MB E550 1/5 Stars
There’s a curious and extremely ugly styling detail on the rear wings of the new Mercedes E-class. It’s a crease that sets off from the back end with much purpose and drive, but when it reaches the door, it sort of gives up and, like the Okavango river, meanders about before giving up on the idea of existing in the first place.
One thing is for sure. It serves no purpose. It will make the car no faster, no more stable at speed and no more economical. And it’s not a traditional Mercedes thing either — it’s not like the BMW Hofmeister kink in the rear window, which is present on all models.
Mercedes says, apparently, it added the crease as a nod to some model in the company’s dim and murky past. Probably the one Hitler drove. But this makes no sense really. When I buy a new iPod, I don’t want it to look even remotely like my grandfather’s gramophone player. So why should I want my new car to have a feature from the days of running boards?
And, anyway, no one is going to say: “Ah so. I see you’ve hinted at the 1942 Doogleburger model with that crease on the flank.” They’re just going to do what I did: spend hours wondering if Mercedes has the first idea about form and function.
I dislike conspiracy theories. The smug, self-satisfied, arms-crossed demeanour of those who would have us believe that Neil Armstrong didn’t walk on the moon or indeed anywhere more exciting than a sound stage in Nevada invariably fills me with an uncontrollable need to set them on fire.
We see the same sort of thing with Top Gear fan sites on the internet.
Every single thing we do is analysed and then dismissed as fake. All the races are staged. Every word is scripted. Every opinion bought and paid for. Recently a deer ran out while I was belting down the runway in a Mercedes. The shot was included in the film and, immediately, the boys were at their keyboards. “Aha,” they said, “the car wasn’t moving. Television jiggery-pokery has been used.”
Honestly, chaps. If we were going to spend a fortune CGI-ing something onto the screen, we’d blow Richard Hammond’s head off. Or detonate Belgium. Certainly, it’d be something a bit more exciting than a horned rat running about on an airfield.
Nevertheless, despite all this, I don’t believe the crease in the E-class was there from the get-go. I may be wrong, of course. But in my mind the stylists did the car and then thought: “Oh dear. That’s a bit boring. Let’s put a styling detail on the rear wings to distract people from the tedium.” Think of it, then, as one of Jon Snow’s ties.
There are more problems with this car. I tested the E 500, which has a 5.5‑litre V8 engine. That means 382 horsepowers and 391 torques. It means 0-62mph in 5.2sec and, you’d think, plenty of excitement. However, there is none. I have experienced more interesting drizzle.
No matter how brutal you may be with the seven-speed gearbox, it is extremely reluctant to put down its paper, extinguish its pipe, change out of its slippers and actually go. Kickdown provokes a reluctant surge of sorts and if you go right to the bottom of the throttle pedal’s travel, right through the carpet and into the firewall itself, the surge becomes a bit more meaty. But if this car could talk, and you did that, it would say: “Oh, for God’s sake.”
Seriously, asking this car to behave like a 5.5-litre V8 super-saloon is like asking a man to empty a dishwasher. It’s technically possible but only if you are prepared to put up with a lot of harrumphing. I wouldn’t mind, but the engine — the only one in the line-up not changed from the previous model — is either silent or making a strained noise you don’t want to hear.
There are other things too. The steering is inert. The brakes feel as uninterested as the engine, and the ride, on air suspension, is disappointing at low speeds. On the move, it’s fine, or even good, but around town, which is where this car will spend most of its time, picking up Cilla Black from functions, it’s as jittery as the Jag XF I recently tested (of which, more next week).
There is, then, absolutely no point in buying the 500 version of this car. You may as well have the diesel, which is less powerful but much more economical and, in the real world, every bit as fast. But if you are going to buy a mid-range diesel saloon, then the E-class simply doesn’t hold a candle to the Jag.
Normally, with a Mercedes, you feel that everything is there for a reason. With the E-class you have that crease on the rear wing — which isn’t — and a lot of things on the options list that border, I suspect, on being a bit gimmicky.
Certainly, if you specified everything, you’d have a car that would buzz and beep and bong more than Apollo 13 after the oxygen tank exploded.
This is a car that can read speed limits and alert you if you break them, that uses radar to decide how much braking force you should use, that spots pedestrians in the dark, that knows about traffic jams ahead and cars that are overtaking in your blind spot and walls that you are about to reverse into. This is a car that shouts at you if you take your seatbelt off or open the door or leave your key in the ignition. And if you shout back, it will respond without fuss or murmur. Individually, some of these things are interesting. Some might even be worth specifying. But combined, they’d drive you mad.
The upshot is that the new E‑class is not as good as the Jaguar XF or the BMW 5-series. It doesn’t look good, it’s boring and, worse than that, it probably signals that the end of the road for the four-door saloon car is not very far away.
Mercedes has always been the company to which we turn for the next bright idea. It was first with internal combustion and first with antilock brakes and first, frankly, with everything in between. But all I see on the E-class is a rounding-off of the edges. A bit of fiddling with an idea that’s out of steam.
In the olden days, the four-door saloon was the only real choice for the consumer. It sat in our lives like fish and chips and the Post Office and British Rail tea. What do you mean, you want a skinny latte? Or an Earl Grey? Or a curry? Or O2? Or a Mac? Choice hadn’t been invented. So you had a Cortina.
Now, though, the family man or woman can have an MPV or a mini MPV or an SUV or a drop-top or an estate or a four-seater coupé. And every single one of these alternatives is better than the traditional three-box idea.
It’s very difficult, as Porsche has just proved with the Panamera, to make a four-door car sexy. And it’s very difficult to think of any new way of making the drive feel different or better than it was in the previous model. Yes, you might find an extra 2mm of legroom here and a slight cut in carbon dioxides there. But, really, the genre is advancing like world records in athletics. A tiny bit at a time towards a moment when going any faster or making things any better will be simply impossible.
Mercedes has always shown us the way forward. But with the new E-class it has shown us that we’re at the end of the line. Some day, then, all saloon cars will be this dull.
Verdict: 1 Star (Out Of 5)
It's on the road to nowhere
http://www.timesonline.co.uk/tol/dri...cle6717935.ece
Old Jul 21, 2009 | 07:25 PM
LexFather
Guest
Posts: n/a
I told yall that rear crease is odd!! I said that since day one.
1 star out of 5 is pretty harsh but I have said the Styling is pretty blah. Jaguar really looks good with the XF here.
Old Jul 21, 2009 | 07:30 PM
mmarshall's Avatar
I thought Clarkson was pretty hard on the car. I reviewed an American-spec E550 just a few weeks ago (at CL request) and, overall, was pretty impressed with it. My main complaint, as with other M-B products, was the awful placement of the two left-hand steering-column control stalks, which made it very easy to confuse the turn-signals with the cruise-control.
Och's Avatar
Och
I think this E class is the least boring E class ever. In fact its not even boring anymore... well, maybe just a bit. I still find it easily best in class, by miles.
Old Jul 21, 2009 | 07:37 PM
GFerg's Avatar
GFerg
CL Folding 25,000
i havent driven it yet, but I have sat inside and looked it over. I really do find this car to be a complete bore design wise compared to the previous version.
The AMG bodykit of course looks better, and you can also option out a rear roof spoiler from the factory if you so choose which I thought fit well.
Old Jul 21, 2009 | 07:44 PM
LexFather
Guest
Posts: n/a
Looks are subjective and this has the busier front end. However it DOES NOT have the AMG kit and it looks PROPER and like a luxury sedan. This is from the factory. I think its beautiful to this day and aged as well as you can ask from a sedan.
The new one is this criss cross drunk teen with a pen design language where they just want to slap lines all over the damn place.
YOU SHOULD NOT NEED HUGE WHEELS AND A BODY KIT. That is not good design. EVERY car looks good with wheels and a bodykit and a drop (well except like the TL).
WHen will some of these designers understand LESS is more. Huge grill, bigger headlights, more fog lamps, more lights, more creases, more lines. SIgh
Old Jul 21, 2009 | 07:54 PM
Och's Avatar
Och
Speaking of Clarkson and Top Gear... I think I watched too much of that, I picked up a bunch of "British" phrases. Am I the only one who finds himself using phrases like "oh, ****!", "rubbish", "boot" and "bonnet"?
Old Jul 21, 2009 | 07:56 PM
Faymester's Avatar
Faymester
Me too ... oh the English
Old Jul 21, 2009 | 08:02 PM
LexFather
Guest
Posts: n/a
LMFAO Me too!! I seem to use petrol, saloon, estate.....
I also got me a 4 foot friend like James May and I drive like Capt Slow in the h.
Clearly I am Clarksons illegitmate son.....Lets pray he never sees an Acura.
Old Jul 21, 2009 | 08:06 PM
Och's Avatar
Och
LOL, I dont use petrol, saloon or estate... yet, but i do find myself saying "coupe" pronouncing the "e" at the end.
But the "oh, ****!" is gotta be the worst... People look at me weird when I use it in public.
Old Jul 21, 2009 | 08:32 PM
vwynn's Avatar
vwynn
i kinda like the front styling.
Old Jul 21, 2009 | 09:02 PM
rsantiago's Avatar
rsantiago
From: Carson, California currently in Makati City, PI
IMHO the E-Class sets the benchmark when it comes to Mid-Size Luxury Sedan practicality, space, interior, trunk space. Even though the W212 may not have the looks of the W211, I feel that MBZ really put effort into engineering of the car overall.
One thing I wish MBZ would do is release a E63 AMG Black Series a la reincarnation of the Classic W124 500E.
Old Jul 21, 2009 | 09:58 PM
DustinV's Avatar
DustinV
Honestly, is the opinion of Jeremy Clarkson really that important? I've never taken anything seriously that has come out of his mouth. The guy is an entertainer. I wouldn't be surprised if he writes bad reviews about certain cars for entertainment reasons. It's one of the things what keeps him in the spotlight.
He has probably already ordered his E63 AMG...
Old Jul 21, 2009 | 10:02 PM
mmarshall's Avatar
In that case, they better pay him well. E63s can run to almost 100K with options (the one I reviewed last year was 94K).
Old Jul 21, 2009 | 10:05 PM
DustinV's Avatar
DustinV
I think Clarkson is a bit of an AMG fan (since he has owned so many), so my comment was meant to come across with a healthy load of sarcasm.
