hey guys,i own a 95 sc400 with a 2jzgte swap auto,,i am in the middle of converting to single turbo(presicion 67) and my power goals would be 600hp...i want to upgrade the fuel system and piggyback system...what do i need to upgrade the fuel system..? i know i will need a walbro fuel pump,upgraded fuel rail,injectors ,regulator is there anything else? and as for as piggy back system...i would need more then a safc..can i use a VPC? i know i am using an aristo ecu but is there anyway i can make a VPC work..i would go standalone but i am on a very tight budget and i know i can purchase a vpc for those who wanting to get rid of them..
so what is the best piggy back i should go with? i figured the vpc will be useless..but i know the safc wont cut it also..would i need to get a mk4 supra ecu? to make the vpc work?
Try looking into AEM's FIC. It's a fuel and ignition controller. You can use an AFC depending on how big you go on your injectors. With an AFC you can only go 50% above the stock size. So for example if you're running 440cc stock you can go up to a 660cc injector and still tune with an AFC. The FIC is a better system because it does more than just fuel it allows you to play with your timing. They are fairly inexpensive somewhere around 400 bucks. Check them out!!
