anyone with 2010 rx?
Old Jul 7, 2009 | 09:53 AM
rominl's Avatar
rominl
exclusive matchup
Default anyone with 2010 rx?
does anyone here have a 2010 rx?
Old Jul 7, 2009 | 10:55 AM
lyyca's Avatar
lyyca
My friend does. It's very nice and comfy ride.
Old Jul 7, 2009 | 01:17 PM
AceM3's Avatar
AceM3
I had he Honor to test drive a few and perform an inspcetion.
Why the question?
Old Jul 7, 2009 | 01:28 PM
rominl's Avatar
rominl
exclusive matchup
Why the question?
did the car you test drove have rses?
Old Jul 7, 2009 | 02:02 PM
AceM3's Avatar
AceM3
Im not sure but you talking of the rear Seat Entertainment System?
Rx350 or 450h?
Old Jul 7, 2009 | 03:09 PM
rominl's Avatar
rominl
exclusive matchup
doesn't matter 350 or 450h, and yeah, i am talking about the rear seat entertainment system
Old Jul 7, 2009 | 06:31 PM
AceM3's Avatar
AceM3
What is your Question?
Old Jul 8, 2009 | 01:52 AM
rominl's Avatar
rominl
exclusive matchup
if you are playing video using the rses, and you put the car in park with parking brake engaged. does the video show up in the front navigation screen?
Old Jul 8, 2009 | 08:35 AM
AsianGirl007's Avatar
AsianGirl007
Lexus Diva
Are you and Ritsa in need of a larger car because you're getting a new addition to your household?
Old Jul 8, 2009 | 09:44 AM
rominl's Avatar
rominl
exclusive matchup
wow, you think so far ahead of us!
Old Jul 8, 2009 | 09:48 AM
AsianGirl007
Lexus Diva
I'm just messing with you Henry, you know I always ask you that every chance I get.
Old Jul 8, 2009 | 11:06 AM
GS3Tek's Avatar
GS3Tek
Why would lexus allow that capability?
Back in the 05+ GX, it wasn't possible without a wire hack
Old Jul 8, 2009 | 12:10 PM
rominl's Avatar
rominl
exclusive matchup
ah ok. so on the gx470 with rses, if you put in a dvd in the rear dvd player, the video won't appear in the front no matter what (stock form)?
Old Jul 8, 2009 | 01:16 PM
AceM3's Avatar
AceM3
Last Modified: 3-3-2009 5.7 D From: 200xxx
Model Year: 2010 Model: RX350 Doc ID: RM0xxx015xxx12X
Title: AUDIO / VIDEO: REAR SEAT ENTERTAINMENT SYSTEM: SYSTEM DESCRIPTION (2010 RX350)
SYSTEM DESCRIPTION
1. OUTLINE
As a unique feature of the Rear Seat Entertainment (RSE) system, the rear seat occupants can enjoy different audio-visual modes at the same time.
The rear seat occupants can control the audio-visual modes with the remote control, and listen to audio by using wired or wireless headphones.
The multi-display controller sub-assembly receives image and sound signals from the display and navigation module display and distributes the signals to each television display assembly.
A television display assembly is installed on the back of each front seat.
The rear seat occupants can enjoy watching video by connecting an external device.
MOST communication is used between the display and navigation module display and the multi-display controller sub-assembly. AVC-LAN communication is used between the multi display controller sub-assembly and television display assembly.
Occupants in the front seats, rear left seat and rear right seat can enjoy different content at the same time. However, this is possible for the rear left and rear right seats only when a VIDEO is selected for either the left or right seat and another source is selected for the other seat.
2. FUNCTION OF MAIN COMPONENT
Component
Function
Television Display Assembly
Displays DVD and video images in accordance with video signals from the multi-display controller sub-assembly.
Receives signals from the remote control and outputs them to the multi-display controller sub-assembly.
Outputs audio signals to the wireless headphones in the form of infrared signals.
Displays the audio-visual control screen.
Displays the adjustment screen.
Displays the diagnosis screen. The diagnosis screen appears when diagnosis mode is started on the multi-display assembly.
Even if the engine switch is turned from on (ACC) to off to on (ACC), display condition continues (image adjustments maintained, sources continue playing on the left and right sides).
Radio Receiver Assembly
Outputs DVD image signals to the display and navigation module display.
Multi-display Controller Sub-assembly (RSE ECU)
Processes video and audio signals from the video terminal and DVD image and audio signals from the radio receiver, and outputs them to the television display and headphone terminals.
Controls the distribution of the audio-visual content to the rear left and rear right.
Outputs audio signals for the video to the front seats.
Remote Control
Outputs various control signals of the RSE system to the television display assembly in the form of infrared signals.
Wireless Headphone
Receives audio signals from the television display assembly in the form of infrared signals.
Volume adjustment of the wireless headphone can be done by using the volume adjuster on the wireless headphone.
Headphone Terminal
Outputs audio signals to the wired headphones that are connected.
Adjusts the volume of the wired headphones in accordance with volume control.
Video Terminal
This terminal is for connecting the video player's video and audio output terminals.
Display and Navigation Module Display
Receives DVD image signals from the radio receiver assembly and sends the signals to the multi-display controller sub-assembly.
Hope This Works...
Old Jul 8, 2009 | 04:44 PM
GS3Tek's Avatar
GS3Tek
^^^did that answer your question then?
yep, cut and snip a couple wires and the rear dvd shows up on the nav screen:
https://www.clublexus.com/forums/gx-...ictures-3.html
