Review Update: 2010 Lexus RX350/450H
The only real differences between the RX450H and the less-expensive, conventional RX350 are with the drivetrain, steering, and braking system, although there are also some trim and gauge differences as well. So, I saw no need to write up a completely new review for the RX450H. What I'll do here, instead, is include my RX350 review below for basic reference and just highlight the differences between the 350 and the 450H.
Here's the RX350 review:
https://www.clublexus.com/forums/car...xus-rx350.html
And here's the RX450 review update:
RX450 dash gauges:
Model Reviewed: 2010 Lexus RX450H AWD
http://www.lexus.com/models/RXh/
Base Price: $43,250
Options:
Comfort Package: $825
12-Speaker Premium Audio/19" wheels: $660
Bi-Xenon HID headlights: $1175
NAV System: $2440
Tow Prep Package: $238
Wood/Leather Steering Wheel/Shift Lever: $330
Cargo-Area Accessory/Wheel Locks: $232
Destination Charge: $875 (this, IMO, is somewhat of a rip-off....similiar vehicles have a freight charge between a $600 and $750)
List Price as reviewed: $52,535
Drivetrain: AWD, transversely-mounted, 3.5L VVT-i V6, Front/rear permanent-magnet electric-drive motors, total system 295 HP (Lexus does not quote HP-RPM or torque-RPM figures for the 450H), CVT Transmission with Manual/Snow modes.
EPA Mileage figures: 30 City, 28 Highway
Exterior Color: Smoky Granite Mica (a darkish gray)
Interior: Parchment (Light gray) Leather with Brown Walnut trim
EXTERIOR:
Outside, there is very little difference between the RX350 and the RX450H. The 450H, of course, has the hybrid logos on it, and a big "Hybrid" emblem on the chrome lower-body running boards. The exterior paint colors, for the most part, are about the same, and the 450H, of course, has the same superb paint job and fit/finish that all Lexus products do outside.
UNDERHOOD:
Terrible. Same hood/struts/insulation pad as the 350, but even worse underhood access. EVERYTHING, except for a couple of filler caps and one or two reserviors, is hidden by covers or down in a big hole on the left side.
INTERIOR:
Pretty much the same as the 350, with the same superb quality and fit/finish. The main difference between the 350 and 450H, inside, is the substitution, on the dash, of a set of hybrid-flow gauges in the area that the big analog tachometer is on the 350. (I included a graphic shot of the hybrid gauges above).
CARGO AREA/TRUNK:
Basically the same as the 350. From what could tell, the 450H's battery pack did not interfere with rear-seat folding for added cargo space....and there are remote rear-seat-releases in back. As an added bonus, the rear seat-backs can recline, like the front, for added comfort.
ON THE ROAD:
Here, of course, is where you find most of the differences between the 350 and 450H. The 450H's hybrid system uses the same 3.5L V6 as the 350, but tweaked to work in conjunction with the front electric motor (two additional rear electric motors are provided for the on-demand AWD mode). Like all Toyota/Lexus hybrids, it can run on gas or electric power alone. On start-up with the power button, like other Ford/Toyota/Lexus hybrids, a green dash light signals all is ready to go. I started out in pure electric mode on the ECO setting, and ran that way briefly, but, if you hit the Power setting for the hybrid system or give it some gas, the gas engine cuts in......you can hear it, but, of course, being a Lexus, the engine/exhaust noise is very quiet. The power level, with both motors operating, is pretty healthy for a luxury-oriented, non-sporting SUV, and gives you a mild shove in the back.....Lexus quotes a 7.4 second 0-60 time. The CVT transmission has an annoying zig-zag shifter, but has (+) and (-) built-in driving ranges. there are no paddle-shifters on the dash....that is done with the lever in the manual-shift gate.
The wind and road-noise level, of course, is super-quiet. Steering response, to me, felt a little quicker and snappier than in the regular 350....perhaps a result of the hybrid's electric steering unit and/or a different steering-gear ratio. Ride comfort, to me, felt a little smoother than the regular 350. The brake pedal was fairly well-placed, with no hang-up problems for my big feet, but, due to the regenerative-braking system common to all hybrids, had a little different pedal feel than the 350. The pedal felt a little mushier at first, and then took hold strongly as you pressed it further down.
THE VERDICT:
I enjoyed driving this smooth, super-quiet, versatile, luxurious SUV as much, if not more, than its 350 brother (and believe me, I enjoyed that vehicle as well). But I'm not sure that the few extra MPG the hybrid system gives is worth the added price (my tested vehicle, with package options, listed for over 52K, about 5-6K more than the similiarly-equipped RX350 I reviewed). The hybrid MPG figures are definitely better then the conventional version, but it still is not that really a high-mileage vehicle like the Ford Fusion hybrid or smaller Toyota/Honda hybrids......the 450's hybrid system seems designed more for power and flexibility than high mileage. The best fuel savings come in the city, where the hybrid gives 30 MPG to the regular version's 18. On the highway, though, the difference is much smaller......the 450 gives 28 to the 350's 24. (Full-hybrids than can run on electric power alone usually give better city figures than on the highway, because the electric motors run more and the gas engines don't cut in so much). So, if you do most of your driving in the city or in stop-and-go driving, you will save more gas, on a proportional basis, than if you take mostly long trips. But the 450 is, of course, an expensive vehicle....the difference in price between a 350 and 450H could buy a lot of gasoline, at today's gas prices.
Anytime.On one thing, though, I agree with you.....I don't care for the console-mounted computer-mouse in the 450H, any more than I did for the same one in the 350.
I saw the new RX in downtown Stuttgart a week ago. Looked pretty good to me (better than the RX it replaces). Had a peek inside too but as nice as the exterior is, I just cannot befriend that disastrously styled interior. There is no doubt in my mind that the workmanship is there, but in terms of design I feel it (and the new HS250h cabin) are pretty "wacky". This type of unsymmetric dashboard styling just doesn't go hand-in-hand with the conservative and balanced nature of typical Lexus design.
The 450h has the 19" wheels which look great, as do the optional LED projector headlights, but 30mpg combined is a pretty huge deal. I would bet the RX 350 would do low 20s combined...probably 22 or 23mpg. If the 450h can pull off an extra 7 or 8 mpg, maybe more in some situations, then I really do think it is worth the price premium when comparably equipped with the 350.
I've sat in the new RX, and I like the modern looking interior much better than the previous RX's
In 10 days, I will finally get to drive a new RX350 loaner when I take my SC430 in for maintainence.
I'm not a fan of that type of styling for several reasaons, not the least being that traditional, squared-off designs usually mean better space efficiency, both inside and out.
No, there did not appear to be any significant quality differences between the two, which is not surprising since, even though it is two different plants, discounting the hybrid/electric hardware, the same basic parts are used and are assembled to Lexus-grade tolerances. In fact, the only newer Lexus vehicle I've seen that I did think have some quality glitches is the 2006-2007 ES350, where some dash creaks/rattles, flimsy parts, and loose tolerances were noted. In 10 days, I will finally get to drive a new RX350 loaner when I take my SC430 in for maintainence.
One, the price difference between the two will probably turn out to be more than just the difference between the two price stickers. Unlike the 350, demand for the 450H currently far exceeds supply. The one I drove yesterday morning, for instance, was the only one at the dealership.....and one of the very few for miles around. It had already been "sold" once, fallen through, and more deposits and/or inquiries made on it in just the short time I was test-driving it. So, it is not only a more expensive vehicle than the 350 to start with, but much less likely to be sold at a discount.
Two, right now, we don't know where the price of gas is heading. It was climbing steeply for the last two months, but, right now, appears to have stabilized or even dropped a little. The cheaper gas is, the fewer benefits, mileage-wise, there are to owning a hybrid, and the longer it will take to recover the price difference, although it is well-known that a number of hybrid buyers don't necessarily purchase them for the gas mileage but for the extremely low emissions.....in other words, to make an environmental statement.
Three, the RX450 AWD, despite a significantly higher city MPG figure (30) to the RX350's (18), doesn't really have much advantage on the highway, where the 450H's difference over the 350 is only 4 MPG (24 to 28) (This is typical of most full-hybrids, because the electrics usually run more than the gas engine in stop/go driving, using less gas). So the real gas savings in terms of gallons to vehicle price, will vary on a number of factors, not just the differences in the two sticker prices.
Four, with a hybrid, you often get Federal/state tax credits and HOV (express rush-hour lanes) free-use priviledges if you live in or near a big city with HOV freeways. Conventional gas-powered vehicles don't get those HOV free-use priviledges unless they have several occupants inside, although, under the new law this year, both conventional and hybrid vehicles get a Federal tax deduction for both the state sales-tax paid on the initial sale and also the interest on the financing (if applicable) .
It would have been nice to do it last February with the 350, but Lexus didn't have the 450H ready until now.Last edited by mmarshall; Jun 25, 2009 at 11:13 AM.
