Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
STOP NOW! ~ Huge Rotor Sale - Brembo, DBA, Powerslot!
Old Jun 13, 2009 | 01:14 PM
CircuitMS's Avatar
CircuitMS
Default STOP NOW! ~ Huge Rotor Sale - Brembo, DBA, Powerslot!
We sell many performance brake pads and rotors. Here are some of the best rotors you can buy for your performance vehicle, at the best prices!
We have gathered the best in quality, performance and value for you.
Just PM us with your vehicle type and what brand rotors you're looking for, plus front or rear pairs.
Brembo - Arguably the biggest name in braking with high standards of quality. Top quality rotors, for slightly more money.
Genuine Brembo Sport High Performance Braking Systems
To improve the performance and appearance of your vehicle, Brembo offers a SPORT High Performance brake system.
Features
• Cross-drilled OR slotted rotors
• Racing inspired Cross Drilled or Slotted Rotors
• Fully compatible with:
- stock O.E. calipers
- wheels
- ABS and traction control systems
and other chassis components
• Pillar venting technology
• Attractive, anti-corrosive finish on most applications
(not available on rotors with integrated hub)
• TÜV certified
Benefits
• Replaces the vehicle’s O.E. rotors without any modifications
• Reduces operating temperatures and fade
• Improves wet weather performance
• Improved initial pad “bite” and break in
• Adds bold, aggressive appearance to the vehicle
• Over 1,000 part numbers for domestic and import cars,
SUV and Truck applications
Brembo Sport systems offer excellent stopping
power, whether it be in everyday traffic or
performance driving.
Pillar Venting Technology
(on selected applications)
The innovative Brembo patented pillar
venting technology increases overall rotor
cooling and provides 40% more resistance
to thermal cracking.
How to recognize genuine Brembo Sport rotors?
• Genuine Brembo Sport packaging
• Brembo Sport rotors are drilled OR slotted,
never drilled and slotted.
Disc Brakes Australia (DBA) - A big name in racing and performance. A good choice for value and performance.
DBA Street Series Rotors
DBA’s entry level enhanced performance rotor, offering improved braking straight out of the box.
Street Series Standard Part Details:
DBA's street series standard replacement disc rotors are designed
and manufactured to perform well under general street driving conditions.
Street Series SlottedPart Details:
DBA's street series slotting improves pad bite and assists to reduce brake fade.
They are the perfect replacement rotor for the performance conscious street motorist.
Street Series Gold (cross-drilled & slotted)Part Details:
DBA's street series GOLD slotted and cross-drilled rotors provide maximum cooling with an attractive,
aggressive appearance.They are the perfect replacement rotor for the performance conscious street motorist.
DBA 4000 Series Rotors
DBA's mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
4000 Series Standard Part Details:
This rotor features Thermal Stability Profiling for
4000 Series Slotted Part Details:
The unique 6x6 Wiper Slot design provides extreme stopping power on the road or the track.
4000 Series XS (premium cross-drilled & slotted)Part Details:
The XS premium cross-drilling and slotting design provides efficient braking performance on the street (for street use only)
DBA 5000 Series Rotors
DBA’s enhanced performance rotor features Thermal Stability Profiling for improved heat handling, Thermo-Graphic paint markings for effective heat monitoring
and Kangaroo Paw ventilation for more efficient braking.
5000 series Fully Assembled 2-piece Black Hat slottedPart Details:
This rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
With a two piece design and an AlumaliteTM centre hat, the 5000 series is one of the finest rotors available.
5000 series Fully Assembled 2-piece Gold hat XS (premium cross-drilled & slotted)Part Details:
Power Slot - Cost effective solutions for braking. Quality rotors at a great price.
Premium replacement rotors
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, our Vac-U-Slot helps push water off the braking surface for better stopping power.
The Vac-U-Slot also serves as a visual wear indicator. The slot is machined to the rotor’s minimum thickness where it crosses the outside edge. If you cannot see the slot along the outside edge, the rotor has worn down to its discard depth.
Power Slot Cryo
When you need something tougher than a Power Slot rotor, but you’re not quite ready for a big brake kit, try our new Power Slot Cryo rotors. We’ve invested in the latest state-of-the-art equipment to offer cryogenic treatment on our Power Slot rotor line.
Deep cryogenic treatment is a one-time process that permanently improves the performance and service life of metals from brake rotors and engine parts, to machine tools and gear sets. Using a proprietary computer-controlled process, the metal is cooled gradually to -300°F and then slowly returned to room temperature and heat-cycled as the final step. Although not apparent to the naked eye, the improvements to the rotor are significant. The cryogenic treatment process redistributes residual stress in the rotor giving it an extra level of protection against thermal distortion and wear.
Old Jun 13, 2009 | 02:02 PM
Trav7414's Avatar
Trav7414
Please pm me on Brembo and Street Series Gold drilled for '04 gs430 front&rear shipped to 76140.
Old Jun 13, 2009 | 04:53 PM
Alexus_300's Avatar
Alexus_300
Please PM me pricing for all DBA rotor type for the front and rear for the following vehicle shipped to zip 27612.
1994 Toyota Supra TT
2001 Lexus GS300
Old Jun 14, 2009 | 01:27 AM
HighImStan's Avatar
HighImStan
PM me for Brembo and Street Series Gold drilled shipped to 94401
Old Jun 14, 2009 | 05:15 PM
love67's Avatar
love67
hi, i was wondering which one is better for mountain/aggressive use? DBA sheet Slotted or the power slot?
Old Jun 14, 2009 | 07:11 PM
dat-is350's Avatar
dat-is350
price for brembo slotted/drilled rotors for and 06 IS350.
Old Jun 15, 2009 | 07:29 AM
Rock-a-Lex's Avatar
Rock-a-Lex
....pm sent!
Old Jun 15, 2009 | 11:04 PM
lilscrapy8's Avatar
lilscrapy8
Price for Brembo drilled 07 IS350
Old Jun 17, 2009 | 10:27 AM
CircuitMS's Avatar
CircuitMS
Pm's sent
Old Jun 19, 2009 | 10:21 PM
Czechlex's Avatar
Czechlex
How much for the Brembo cross drilled or slotted rotors for a 01 GS3 shipped to 92865? Also, does the Pillar Venting Technology apply for my car? thanks
Old Jun 20, 2009 | 05:22 AM
br3akenout's Avatar
br3akenout
price for brembo rotors for 06 IS250awd. Can i get quotes for both cross drilled and slotted. Shipped to 07304. Thanks!
Old Jun 21, 2009 | 04:39 PM
lexus_west's Avatar
lexus_west
price for DBA 4000 Series XS rotors for and 06 IS250
Old Jun 21, 2009 | 10:20 PM
HGill's Avatar
HGill
PM a price for lowest priced front rotors for 99 GS400....Thanks
If possible with shipping to 84121
Old Jun 22, 2009 | 10:26 PM
CircuitMS's Avatar
CircuitMS
Pm's sent!
Old Jun 23, 2009 | 12:44 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
Front DBA 5000 for 1997 Supra TT shipped to 11224 Brooklyn NY, Thanks
