Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
HKS Exhaust-Coilovers-Filters, Eibach Suspension & SPC Adjustable Camber/Caster Arms!
Old May 8, 2009 | 10:59 AM
CircuitMS's Avatar
CircuitMS
Default HKS Exhaust-Coilovers-Filters, Eibach Suspension & SPC Adjustable Camber/Caster Arms!
This pair of Lexus GS front upper control arms will give you ±1º Caster and
±2º camber change. These arms replace the OEM front upper control arms and allow you to adjust camber and caster to your specified settings. These are perfect for anyone who has lowered thier car with springs or coilovers.
Fits:
98-05 Lexus GS 300
98-01 Lexus GS 400
01-05 Lexus GS 430
We carry all SPC performance suspension pieces. From fully adjustable arms, sliding ball joints and static bushing replacements. If you have lowered your car and want to perfect your alignment you need these products! We have camber/caster solutions for all these Lexus models.
'01-'05 IS300
'90-'91 ES
'92-'09 ES
PM us for awesome pricing on all SPC items!
Eibach produces some of the highest quality springs in the world. They can be found everywhere from high performance street cars to full race F1 cars. Eibach springs are built from the ground up - starting with full research and development for every application to determine the best balance between performance and ride quality. Eibach springs are on average 2.75 pounds lighter than the competition. This reduction of unsprung mass is equivalent to removing 50 pounds from your car! All Eibach springs come with an unbeatable Million Mile Warrantly. Pro-Kit The Eibach Pro-Kit will greatly improve handling with a moderate drop that is perfect for a daily driven car. The reduced wheel gap will make your car look the way it should have come from the factory, and the lower center of gravity dramatically helps in the corners. The Pro-Kit features a progressive spring design for the ultimate mix of comfort and performance.
Pro-Kit Lowering Springs:
#8288.140 - Fits: IS250 $250.00
-Lowers 1.4" front and 1.0" rear
#8287.140 - Fits: IS350 $250.00
-Lowers 1.0" front and 0.8" rear
#8285.140 - Fits GS430, GS350 & GS300 $260.00
-Lowers 1.5" front and 1.0" rear
#8282.540 - Fits RX330, RX350 & RX400h $250.00
Anti-Roll Kit:
Reduce body roll and fine tune your handling characterictics with a set of Eibach Anti-Roll-Kit front and rear swaybars. These sway bars are manufactured from cold-formed, high-strength aircraft-grade steel. Anti-Roll-Kits include all necessary mounting hardware and instructions for easy installation.
Includes both front and rear swaybars.
PM for pricing on different models.
We proudly carry all HKS items. Coilovers, Exhuasts, intakes, fuel and engine management, turbos, intercoolers, superchargers, meters and blow-off valves. If you don't see it here just PM us and we can get it for you.
HIPERMAX III CLX
Series Concept: Designed and tuned for luxury performance.
Hipermax III CLX is the proof that luxury and performance need not be mutually exclusive. Designed for BMW, Infiniti, Lexus, Acura and other premium brand automobiles, the CLX series Hiper Linear Piston combines smooth, quiet ride characteristics with enhanced handling capability and the ability to set precise ride height for reduced pitch and roll with the shock-body-length-adjustability feature (most applications). HKS' new reinforced rubber mounts provide unsurpassed insulation from road harshness, while thick, chrome plating on the cylinder shafts and standard dust boots provide excellent durability and longevity. Tuned specifically for challenging expansion joints, uneven pavement and the frost heaves of North American roads, Hipermax III CLX is possibly the single best upgrade you can offer your luxury performance automobile.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Lightweight Aluminum lock nut & ride height adjuster
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Dustboots standard
• 1 year limited warranty
Fits IS250 and IS350 - $1,895.00
Springrates = 5k/5k
GS430, GS350, GS300 - $1,895.00
Springrates = 7k/6k
Hi-Power Exhaust
Inspired and designed from endurance and GT racing in Japan, HKS developed its Hi-Power Exhaust system for both turbocharged and naturally aspirated applications. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. This is achieved by eliminating unnecessary bends for the straightest exhaust path.
Available for these models:
GS300 1998-2005 3.0 ; Dual Rear Sections
GS300 2006 ; Dual Rear Section (w/sound resonators) & Y-Pipe
GS350 2007 ; Dual Rear Section (w/sound resonators) & Y-Pipe
GS400 1998-2000 4.0 ; Dual Rear Sections
GS430 2001-2005 ; Dual Rear Sections
GS430 2006-2007 ; Dual Rear Section (w/sound resonators) & Y-Pipe
IS250 2006-2008 ; Dual Rear Section w/ Y-Pipe
IS300 2001-2003 3.0 ; Rear Section
IS350 2006-2008 ; Dual Rear Section w/ Y-Pipe
PM us for special pricing on different models!
HKS’ high-performance Super Hybrid Filters are a direct replacement for OE panel filters when a factory airbox is required or preferred. Super Hybrid Filters features a 3-layer dry-type filter. The filter element is bonded to a flexible nylon frame and offers a price-friendly performance alternative to a full intake system.
Available for:
GS300 1998-2003
GS300 2006
GS400 1998-2003
IS250 2006
IS350 2006
SC300 1992-2000
SC400 1992-2000
Old May 8, 2009 | 02:01 PM
kyang91's Avatar
kyang91
Do you have any anti-roll kit for the 07 GS350 AWD? If you do PM a price ship to 47906 thanks.
Old May 9, 2009 | 07:53 AM
casper10's Avatar
casper10
Pm sent on ISF Exhaust
Old May 10, 2009 | 06:06 PM
SurfsUP's Avatar
SurfsUP
Please pm price for exhaust for 97 sc300 to 89113.
Old May 11, 2009 | 03:49 PM
CircuitMS's Avatar
CircuitMS
PM's sent guys!
Old May 11, 2009 | 06:24 PM
KpXMystic's Avatar
KpXMystic
do you guys have HKS Intake by any chance? Is so please post it up =)
Old May 12, 2009 | 07:46 AM
CircuitMS's Avatar
CircuitMS
HKS does not list an intake for the IS.
We do have K&N intakes though.
Old May 12, 2009 | 03:33 PM
matrixgts's Avatar
matrixgts
exhaust for sc300 97 to 27529
Old May 12, 2009 | 06:29 PM
rac2max's Avatar
rac2max
HIPERMAX III CLX for IS250 shipped to 20910. Thanks
Old May 12, 2009 | 06:52 PM
excluesive's Avatar
excluesive
quote for SPC upper control arm for 2001 gs430. shipped to 11373
Old May 14, 2009 | 10:26 AM
CircuitMS's Avatar
CircuitMS
Sent you guys PM's
Old May 15, 2009 | 11:30 PM
CircuitMS's Avatar
CircuitMS
Pm's replied.
Old May 17, 2009 | 10:22 PM
CircuitMS's Avatar
CircuitMS
All pm's replied.
Old May 18, 2009 | 06:24 AM
lexusscturbo's Avatar
lexusscturbo
Quote for the UCA's for a 2GS?
Shipped to 90504?
Old May 19, 2009 | 11:37 AM
CircuitMS's Avatar
CircuitMS
Pm sent
